hold down bolts 1960 hardtop
Hello, I need some help. Does anyone have the measurements for the 3 hold down bolts in the deck lid for a 1960 hardtop ,front ,back ,side Thanks,Mike
Received 3,768 Likes
2023 C1 of the Year Finalist - Modified
2015 C1 of the Year Finalist
I'm not sure your question is clear. Do you need measurements for the BOLTS, or, for the location of the bolt HOLES???
2023 Restomod of the Year Finalist
That's what I did. My car was never drilled for one so I mounted the hardtop, marked the locations, removed it and drilled the holes and mounted the hardware. Reinstalled top and it lined up perfectly.
[QUOTE=59BlueSilver;1593548467]That's what I did. My car was never drilled for one so I mounted the hardtop, marked the locations, removed it and drilled the holes and mounted the hardware. Reinstalled top and it lined up perfectly.[/QUOTE I need the measurements to get a reference point to straighten my lower bow.My car did not come with hardtop ,bow is bent that would give me 5 points to use ( the front pins and the 3 bolt holes) too finish rebuilding my top, then I will mount and drill holes Thanks,Mike
2016 C1 of Year Finalist
From what I have seen there are 2 or more problems that can contribute to poor hardtop fit.
First, if a hardtop is stored improperly it will change shape and the side hold downs will spread not necessarily evenly so that can be a problem.
Also depending on the year, the rear bolt location can move.
The second problem is the fit of the windshield (C1) to the body. If a hardtop is not used to test the placement of the windshield it can really screw things up.
On an existing hardtop car the adjustment of the deck lid can also have a small effect.
I have had at least 3 C1 cars where the hardtop fit was a problem.
Good luck.
Bruce B
Good luck.
Bruce B
Received 6,521 Likes
C2 of Year Finalist (track prepared) 2019
Anecdotal evidence:
The hardtop for my '63 was stored improperly for 20+ years. When finally re-installed, there was a 3/8" gap above the vent window frames due to distortion of the fiberglass.
Withing two weeks of being back on the car, however, that gap disappeared and the top once again fit perfectly.
Jim
60 hardtop
I am going to try 1 more time. can someone please give me the measurements for the 3 holes that bolt down hardtop 1960 corvette. I know they are not all the same but I would just like to have them from someone that has a hardtop that has been mounted on their car and taken it off front,back ,side from edge of deck lid Thanks,Mike
Received 3,443 Likes
From what I can interpret from your posts, you don't have a complete hardtop ready to bolt on yet, but you want to drill the mounting holes. If I am correct in my interpretation, I would recommend finishing the hardtop restoration, and then doing what 59 BlueSilver said. It will fit for sure because it will be the top you are using on your car.
