Got My Transmission Back
Well guys I got my transmission back from the mechanic.
There's some slight play where the shift rod meets the gear rod (around the pin). Is that normal or acceptable? It seems to shift fine.
The guy said it looked fine on the inside. He replaced the seals and lubed it for me.
Thanks,
Dex
Thanks,
Dex
Received 3,443 Likes
Hurst sells bushings, both nylon and metal for the shift rods if needed. I use them on my GTO. Why did your friend spray the whole she-bang silver?
You mean you DIDN'T paint your engine Chevy orange? Sacrilege! Is that even legal???
Just kidding, I paint 'em black too but I'm sure that's what some of the purists on here are thinking!
Received 1,534 Likes
"There's some slight play where the shift rod meets the gear rod (around the pin). Is that normal or acceptable? It seems to shift fine."
Remove the Jesus clip and inspect the hole in the lever, if not egged, it is fine. Inspect the rod end for wear. If worn, you will see the groove in it.
Some clearance is needed, but you don't want the rod moving much without moving the lever.
Then the real fun is getting the Jesus clip back in.
The nice thing about cars is you can dress them the way you want
Don't try that with a women.
Looks like I did get "lubed". He told me that he didn't replace the rear seal....but did everything else, so after I put the transmission oil in I saw a few drops that had leaked from the rear seal, overnight. I stood the transmission up to look at the rear seal and this is what I found after I laid it back down:
Guess I need to figure out if I can replace the front and rear seals myself or take it to a transmission mechanic. I'm pretty handy at doing this stuff, but I never have.
Thanks,
A Disappointed 58n65
Thanks,
The rear seal requires a transmission yoke or special mechanics rear sealing tool to properly seal up the rear of the unit. Standing the trans up WILL result in you losing just about all of the trans lubricant.....no matter whether it has a new seal or not.
You should be able to see the rear seal condition with a good flashlight. It is not a hard job to replace it now or later. Just need a seal puller (cheap ones available) and a piece of proper size PVC or other plastic pipe to help with the install. But now is probably the best time to do it.
Larry
Larry
Larry
Larry
i have a rear seal that came in the kit I bought originally. I don't mind buying the tool if I can do it myself. I would say the rear seal leaked about 10-12 drops overnight.
Thanks,
58n65
Location: "You may all go to Hell- and I will go to Texas- Davy Crockett
St. Jude Donor '12
Thanks,
Thanks,
Thanks,
58n65
Merry Christmas Dex. Glad vettesplit 63 and I could help.
Larry
PS: This is why you also don't overfill the trans, as the excess fluid will come out the front unto the clutch disk or possibly work itself out the back unto your garage floor.
Agree..........the front has no seal whatsoever. The rear has a seal, but it requires the trans yoke to be installed to complete the overall sealing. Just about everyone who has pulled the trans in the past for repair or to replace the clutch has had transmission fluid spilled all over their chest. That was how we learned to seal it with a plastic bag and masking tape or spring for the $10-15 for the special rear seal plug (I now keep TWO of these special tools/plugs in my garage )
Larry
Larry
Thanks,
Dex
Although there is a gasket at the front bearing retainer, there is no seal around the input shaft on the transmission, so fluid can leak out regardless. You can check for the gasket, but there is no front SEAL.
If the transmission is not in the car yet, just look at the transmission output shaft in the rear. It has splines like the input shaft. You should see the rear seal (Pic #35) around it. If the transmission is in the car, you will need to remove the driveshaft. The forward end to the driveshaft contains the transmission yoke. Pulling the driveshaft should either remove the yoke or allow you to simply slide it out of the transmission rear. Sometimes you have to disconnect the yoke from the driveshaft for removal clearance.....depending on your car and what is in the way of the driveshaft.
A cheap seal puller should allow you to get the seal out. I will find a picture of one for you and post it. Clean up the mating surfaces, apply a small amount of Permatex #2 on the new rear seal and tap it into place with a small hammer and perhaps using the small section of PVC to provide the final alignment and seal. I think a 6 inch or so piece 1-1/2 inch or 2 inch PVC piping will get be what works. Make sure you install the seal in the correct lip position.
Larry
EDIT: I believe this puller should work. https://www.amazon.com/Lisle-56750-S.../dp/B0002SRCKG
And for your additional enjoyment, here is a link to the special transmission rear plug I talked about earlier. They are getting hard to find anymore. http://www.speedwaymotors.com/Alumin...Plug,1948.html
Larry
Larry
Larry
Thanks,
Dex
Merry Christmas to all!!!
