1957 seat belt identification ??
I have a quite original 57 that only had a drivers seat belt so i ordered replacements for both sides from one of the the suppliers. The car is Aztec copper and the seat belts are some kind of brown that matches nothing but i understand that is correct.
My question is about the one that i removed. the more i look at it the more i realize it has been there a long time. Online searches suggest it may be an original dealer installed set from 1957.
Does anyone know what the original GM supplied belts might be. These are a blue/grey color and say Irving Air Chute on them ( see photos). If they are originals I would like to clean them up and use them in the car.
Please take a look and offer your opinion and comments on what you think.
Thank you
Thank you
There really is no anchor as they loop through a mount (metal loop) in the floor and go back into and out of a latch(2 slotted metal piece)?? of sorts that holds the two sides of the belt together.
Glenn
Hi again
I thought I would find where I got the idea these could be original dealer installed versions. It is a bit of a stretch with the info given, but maybe one of the wizards has walked this street.
Thank you again for anything you can add...
Glenn
Link http://www.earlycorvettes.com/corvet...elts56to57.pdf
Glenn
Based on the black 4-row webbing, anchors and gray hammertone latches, I believe the belts you have there are "Custom Accessories" belts offered by Chevrolet dealers in 1958 & 1959.
Verne
67Sunfire (12-02-2016)
According to Barbara Spear , author of "Corvette Seatbelts 1956-1976"
Buckle front -Plain or chrome plated
Webbing design- 6- bar, nylon
Color- Silver -grey
Tags- varied according to manufacturer ( example Brown Line Corp of Beverly Hills - Model # WB 2020) Irving Air Chute was the other manufacturer
The seatbelt anchor was mounted at the factory in the 2 lower holes of the reinforcement; the belts were a dealer accessory kit.
Color- Silver -grey
Another possibility is that they are '58 seat belts. '58 was the first year they were standard factory installed and they came in one color, blue gray (some would say silver blue). The buckles were finished in a hammertoe finish (which these are) and were painted a matching silver blue. I am sure that these could have been purchased through the Chevrolet parts desk and installed into a '57 pretty easily. Any other dates or numbers on the label?
No other dates or marks on the belts. i am getting a good picture that they are the 58-59 accessory belts based on the replies here. The belt is definitely a silver blue as you call it. I undid the one area in the latch that had not moved in decades and that was the original color.
Amazing knowledge base this place is.....
Now that i know the ugly brown/tan belts I bought are all together incorrect, i was able to buy an original reconditioned set of the blue/gray belts from Corvette central. Not free but correct and the car is very correct so far.
Thank you everyone for the input and direction on this matter. I will not drive the car without belts, this fixes that issue.
Glenn
Glenn
Glenn
Glenn
Good evening
Navigator
'57 seatbelts
I'm very late to this discussion, sorry. I have schematics of seatbelt installation for the '57 Corvette. I can't remember where I got them, but my recollection was that seatbelts were a dealer-installed option. And they were all grey. Installation required an inner bracket (481421) and an outer bracket (481422). My '57 had the brackets already in place. It seems to me that this belt could be an original dealer option.
Navigator
Irving Airchute seatbelts for a '57 corvette
[QUOTE=67Sunfire;1593585368]I have a quite original 57 that only had a drivers seat belt so i ordered replacements for both sides from one of the the suppliers. The car is Aztec copper and the seat belts are some kind of brown that matches nothing but i understand that is correct.
Thank you
According to the several posts on the internet, including this one http://image.mamotorworksmedia.com/p...seat_belts.pdf, seatbelt mounts were provided in '56-'57 corvettes, but seatbelts were a dealer option that required added brackets. Irving Airchute provided the seatbelts. I think you have an original seatbelt.
Thank you
Hi again
Glenn
Glenn
2020 C1 of the Year Finalist - Unmodified
Corvette of the Year Finalist 2018
2017 C1 of Year Finalist
2015 C1 of Year Finalist
For what it's worth, I was crawling under a friends early 56 this morning and noticed the underbody seat belt reinforcements. His car has no seat belts and is all original. Perhaps GM installed the reinforcements with an eye towards dealer installed options later.
Edit: Looks like the link provides that answer as well!
FDC1650 Davis Aircraft. Not Corvette, but supplied to '57 Black Widow race car. Available over the counter at dealers because the race cars had to be "factory". You had to know the part number to order them.
1958-62 Corvette, factory installed
Back side of Brown Line 56&57 Vettes
Brown Line. Dealer installed for '56 & '57 Vettes
Documentation for FDC1650 Black Widow sedans. Notice the bench seat. Not Vette.
