Alternator converrsion
I am trying to find mounts for a 62 vette when going from a gen. to a Alternator original 327. what type of mounts will work when installing the alternator
They make kits to convert an alternator to tach drive conversion kit...you'll have to figure out which way/one to go/use...
I know you needs brackets but, Worth a look...
https://www.google.com/search?q=tach...W2vAHsQ7AkIjAE
Or you can look/check out ollllld farm equipment...as they used 'tach drive alternators back then...
Search 'TACH DRIVE ALTERNATOR' in google...
He needs brackets, & unless he has headers, I can't help him.
Plasticman
Here is a start:
https://www.summitracing.com/search/...et%20chevrolet
You may also try Alan Grove, since he makes a lot of brackets.
http://www.alangrovecomponents.com/
Jack,
62's all used the dist. tach drive, and I believe was the first year like that. Previously, only the FI engines used the dist driven tach (tach drive was off the rear of the generator on the carb fed engines).
Plasticman
