Dust Cover Removal
I have not noticed those separately available and I think they are more than pressed on, but not sure. But - bump to the top in case someone knows.
pop23235 (12-02-2016)
I'm sure these are separate items, assembled for installation as the shaft is likely an alloy that is machined and the deflector is stamped steel. I've purchased them from ZIP. From the looks of them, they would be pressed on, but may be welded or.......
You are already well ahead of me on this. My experience so far is that the hardened tip wears down long before the shield rusts away.
