[C2] Transmission car won't move in gear rolls in neutral
I have a 1964 327 , 365hp, 4 speed. When I put it in gear it is like I have the brakes on and it stalls the engine when I start to release the clutch . I have tried first , 2nd reverse with the same issue, I can put it in neutral and it will roll with no issues .
Dies anyone have ideas what could be the issue
thanks
thanks
Sounds like the Shifter arms/rods are binding...crawl under there and move the rods/levers...
The 1-2 and 3-4 levers on trans should be vertical...
Or you have a pilot bushing issue...
If its not the levers binding...
You'll have to pull the transmission...to get to the pilot bushing...but wait until others chime in to get some other opinions...before you tackle the trans...
I just know that one time right after i had put in a new bushing, the darn car wouldn't move...
So my friend came over and checked things out, 'shifter' levers/rods, he said i had probably damaged the bushing on install...so out it came, sure enough i had damaged it...got it all back together and took my time in/on the install and its worked like a charm for the last 3 years...
I will start with the levers/rods, , I can't get back to the car until Friday to check. It happened one time prior and I rolled the car a couple inches and it was fine, not as lucky this time
Hi Dnaper64, I just went through this process with my '65. I followed the Forum's advice and replaced my shift levers and ordered a new old Muncie shifter. I installed them weekend, but due to snow, no road test yet. Shifter seems a lot tighter. Good luck. Chuck
Received 4,583 Likes
C1 of Year Finalist (appearance mods) 2019
Check to see if your clutch isn't stuck on the flywheel. Was the car sitting for a long time before you tried it? Once in a while my car will do that exact thing. You have to put it in reverse or first depending on which way you can go and start it in gear....this usually will make the car lurch in that direction and within a second or two the clutch will free up. Just make sure the way is clear....
It's worth a try anyway, especially if there was no indication of anything wrong before.
I just drove the car , I was re positioning it in the garage, pulled back , then forward , then that was it , stuck. when I tried it in 1st 2nd and reverse , same result , just stalls
I can't get to the car until Friday , but will see if the clutch is stuck on the flywheel
thanks for the suggestion
Kerrmudgeon (12-05-2016)
St. Jude Donor '05, '09, '15
My logic, for ever that's worth, is this.
Trans not stuck in two gears because it rolls in neutral.
If clutch was stuck he wouldn't be able to put it in gear with engine running or it would drive away. Not stall the engine when the clutch was engaged.
The only thing I can think of is shifter is moving 2 trans levers at the same time. Which puts the trans in 2 gears at once and puts them
Back in neutral together as well. I have never seen it before.
I would he the car up on jack stands and have someone shift it and watch what happens with the trans levers.
JMHO
Tom
JMHO
Tom
Time for a linkage adjustment...
Tom as crazy as it sounds , it almost feels like the car is in 1st and reverse at the same time. I need to get under the car and check out all the suggested posts then get back to everyone with what I find. certainly a first for me
thanks
thanks
Post #7 is a picture and dimensions of tool you'll need to do the adjustment...if you don't want to purchase one, you can make on out of a 'church key', can/bottle opener...
https://www.corvetteforum.com/forums...ment-tool.html
:::EDIT:::
Check out this link also...
https://www.corvetteforum.com/forums...uge-lenth.html
:::EDIT:::
Dnaper64 (12-05-2016)
JMHO
Tom
JMHO
Tom
Believe the suggestions about linkage are on target. When I had this problem I found that some of the rod holes in the shift levers were elongated from years of shifting. New levers should fix the problem or "Bubba it" like I did by welding up the wallowed holes and redrilling the proper size.
Since you stated you have a Hurst Shifter, note that it's alignment key can typically use a 1/4" Allen (hex) wrench or a 1/4" diameter rod bent to fit up "there". I don't think it uses the same alignment key as the stock shifter.
Also, you may just find the shift rod bushing are simply "gone" (either broken or worn). Hurst used 2 different types of interchangable bushings - plastic and metal. Plastic are less noisy (less rattle), but don't last as long as the metal version. Those bushings being damaged or missing may allow sufficient slop for 2 gears to be engaged at the same time.
Plasticman
Plasticman
I missed the HURST SHIFTER post...
