breakerless ignition and radio noise - Page 2 - CorvetteForum - Chevrolet Corvette Forum Discussion
C1 & C2 Corvettes
General C1 Corvette & C2 Corvette Discussion, Technical Info, Performance Upgrades, Project Builds, Restorations
Old 02-13-2017, 07:01 PM   #21
69427
69427's Avatar
Location: I tend to be leery of any guy who doesn't own either a chainsaw or a handgun.
Quote:
Originally Posted by alexandervdr View Post
If that means going back to breaker points, I am probably not going to try that (please don't turn this into a points versus electronics thread! Both sides are right, but one can only go one side...)
The capacitor on the C+ terminal is there to reduce/prevent noise being induced into the vehicle harness and into the radio power supply. Once you have the cap in place then you need to address the plug wire issue. Low resistance/reactance plug wires allow a high current spike to occur once the plug arcs over. This high current pulse radiates everywhere, both into the wiring harness and into the antenna. If you can slow down/reduce the plug current spike it should help reduce the noise in the radio. Let us know how things are when you change the plug wires.
69427 is offline   Reply With Quote
Old 02-13-2017, 11:48 PM   #22
Pilot Dan
CF Senior Member
Pilot Dan's Avatar
I am surprised nobody asked if you were running a stock or aftermarket (newer) radio, some of which require additional wiring and grounds.
Pilot Dan is offline   Reply With Quote
Old 02-14-2017, 08:38 AM   #23
Frankie the Fink
Hobbyist..
Support Corvetteforum!
Frankie the Fink's Avatar
The aftermarket radios I have run have a big bolt that goes into the PS side mount point and thoroughly ground the case....the AAR repro for instance; I guess there are others that might float in the mounting and require a separate ground... Its also possible the radio has a defect as the Bluetooth works whereas broadcast stations do not (without noise)...
This last factor is a key clue - it may preclude noise introduced into the power line...
Frankie the Fink is offline   Reply With Quote
Old 02-14-2017, 09:31 AM   #24
jim lockwood
CF Senior Member
jim lockwood's Avatar
That's not quite a fair comparison. Bluetooth thingys operate in the 2.4GHz range while FM broadcast is waaaaay down there at 0.1 GHz. It's unlikely that any noise source, such as ignition, could generate any noise energy up at 2.4GHz.
Jim
jim lockwood is offline   Reply With Quote
Old 02-14-2017, 09:38 AM   #25
Frankie the Fink
Hobbyist..
Quote:
Jim
That is true.
Its easy enough to tell....if the radio has an AUX or pin jack just play some tunes through that for a bit and see if the whine is there
Frankly, I could have changed the plug wires in the time its taken to produce this thread...
To the OP: I wouldn't worry two nits about resistance plug wires creating "weak" spark....its a non-issue for about 98% of our cars running the streets...
Old 02-14-2017, 12:25 PM   #26
jim lockwood
CF Senior Member
Jim
And I just thought about something else which would make Bluetooth thingys immune to ignition noise...... in all probability they communicate digitally which is about as noise-immune as you can get.
AM and FM broadcast both use analog technology, which is inherently more susceptible to radiated noise.
Jim
Old 02-14-2017, 02:27 PM   #27
Jackfit
CF Senior Member
Jackfit's Avatar
I installed the breakerless ignition unit breakerless.com in my original (but new) C2 small block distributor. I now get spark noise in my FM radio, is this normal?
All these little things.....lets see the car....some video of it moving.....I think it is all made up.......lol......Ingrid , take some pictures while he is out.......
Jack
Jackfit is offline   Reply With Quote
Old 02-14-2017, 04:00 PM   #28
alexandervdr
CF Senior Member
all the comments make sense, I am now waiting for the higher resistance spark plug cables to cross the ocean (and the customs...)
That may take days or weeks, depending on the temper and mood of the 'red tape' .
As soon as I have tested them , I will let you know my findings
by the way: did I tell already that I installed the distributor top ignition shield , did not make any difference.
alexandervdr is offline   Reply With Quote
Old 02-15-2017, 04:50 PM   #29
Avispa
CF Senior Member
Avispa's Avatar
Still trying to figure out how the OP is having noise trouble with FM (he didn't say whether AM was affected). FM is essentially immune to most electrical noise from sources in the car like plug firing and power switching. All those noise suppression capacitors are for AM, which will pick up any amplitude-change electrical noise that has frequency components in the bandwidth of the 455 KHz intermediate frequency amplifier. Unshielded graphite core plug wires usually don't have any effect on FM. A strong AM broadcast signal will usually override noise from unshielded graphite core plug wires.
The OP also didn't mention what kind of "high performance" plug wires he got from Zip. All I could find in their on line catalog were Pertronix wires, which are good ones for noise suppression - graphite center core with spiral wound resistance (nickel chrome or monel) wire covering the graphite. These wires generate less radio noise than uncovered graphite core wires because of the spiral wind of the resistance wire. The field generated by spiral core wires runs along the length of the wire, rather than perpendicular to the length of the wire (the same for graphite core or copper solid core wires).
Something else is going on beside the plug wires and breakerless ignition.
Avispa is offline   Reply With Quote
Old 02-15-2017, 05:36 PM   #30
alexandervdr
CF Senior Member
Quote:
Originally Posted by Avispa View Post
The OP also didn't mention what kind of "high performance" plug wires he got from Zip. ....
what I got was "57-74 Performance Spark Plug Wire Set" from ZIP
Item #: M-3962
Old 02-16-2017, 02:47 PM   #31
Avispa
CF Senior Member
Avispa's Avatar
Alexander, I just checked the wire set you mentioned. They're 250 ohms/foot. I'm running Bosch spiral core wires (50 ohms/foot stuffed in correct BBC braided wire shields). I'm also running a mallory unilite module as a trigger and an old MSD 6A analog box to jolt the coil. NO noise on FM or AM. You've got a radio problem. Your ignition mods just don't create enough RFI to put noise in a properly working original Delco radio with factory ignition shielding. Especially on FM.
Old 02-16-2017, 05:46 PM   #32
alexandervdr
CF Senior Member
Thanks for this detailed info. The braided part of your set-up may have an impact? Note that I have a modern Pioneer in there. Thats' the one that 's having the noise problem.
Where did you get the 250 ohms/foot info of the wires I bought? It's not on the ZIP site.
Old 02-16-2017, 06:58 PM   #33
426 Hemi
CF Senior Member
426 Hemi's Avatar
Maybe the alternator/regulator is inducing some noise. Could pull the belt and test real quick.
426 Hemi is offline   Reply With Quote
Old 02-16-2017, 07:33 PM   #34
Avispa
CF Senior Member
Avispa's Avatar
it's on their mobile site at
http://www.zip-corvette.com/57-74-performance-spark-plug-wire-set.html
Go Back   CorvetteForum - Chevrolet Corvette Forum Discussion >
Reload this Page
  • breakerless ignition and radio noise
    Related Topics
    Thread Thread Starter Forum Replies Last Post
    [C2] Breakerless Electronic Ignition recommendation jackson 63 C1 & C2 Corvettes 7 06-13-2016 08:06 PM
    coil for breakerless ignition alexandervdr C1 & C2 Corvettes 16 04-25-2016 08:58 AM
    Distributor Breaker Plate Removal Kelley C1 & C2 Corvettes 11 06-17-2010 10:06 AM
    Going from points to breakerless - which brand? AirTrafficController C3 Tech/Performance 34 04-03-2007 09:22 PM
    Converting a '72 Distributor to Electronic Breakerless Ignition. Which is best? cor72vette C3 Tech/Performance 9 09-30-2002 10:17 PM
    Search this Thread:
    Click for Advanced Search
    Posting Rules
    You may not post new threads
    You may not post replies
    You may not post attachments
    You may not edit your posts
    BB code is On
    Smilies are On
    [IMG] code is On
    HTML code is Off
    Trackbacks are Off
    Pingbacks are Off
    Refbacks are Off
    Forum Jump
    • Ask a Question
    What's your question?
    Send
