Help with a '66 rear brake pad
Sure a lot of 'rust' on the metal part of pad...i think its from just setting and the pads adhered to rotor...
Dennis Beck (12-12-2016)
Was the back of the pad wet? If so, a slow piston seal leak would allow fluid to flow to the outboard low corners and travel around and up to the pads by capillary action... maybe.
Received 1,843 Likes
Any chance that whoever put those pads on missed the pin hole on the inside pad and it dropped down a rubbed on the dust shield? The pad looks like it has some wear on the top up by the pin hole, none at the bottom except where the mice have been chewing on it.
Wouldn't the 'metal' part be worn before the pad...
Received 1,581 Likes
St. Jude Donor '20-'21-'22-'23-'24
Dennis - Were you the person who originally installed that pad? If not, maybe whoever did the job installed a damaged pad.
I would hate hate to think anyone would do that on purpose, though.
Steve
Steve
Thanks for all the ideas guys. I will get on it and report back.
Dennis
This is a wonderful academic exercise. Like the others I have never seen a pattern such as this and have no explanation for same. Considering that the "rolling" noise had gone away, you may never find a cause. I would consider replacing the brake pads and forgetting about the entire episode. Don't be concerned unless the noise returns or you notice a fluid leak.
Dennis
