Help with 64 Clock needed ( PICTURES)
https://www.corvetteforum.com/forums...37262082372444
Trying to repair my original works clock, and figured it was just going to need the points filed, and the gears lubed. But it turned out that the small wire from the relay was broken off as you can see in the first 2 pictures. So I figured it just needed to be soldered back on, but when power was restored, it ran but the wire heated up and started to smoke, so I'm thinking obviously the relay is bad.
I am well aware I can just get a quarts replacement kit, but I would really like to be able to just fix it as is, so with that being said does anyone know where I can get just a new relay?? I have searched tons of places and archives, but can't seem to locate anything other than the afore mentioned quartz deal.
Any help or advice would be greatly appreciated...
The bakelite where the relay is mounted appears to have gotten hot which would support your idea that the relay is bad. The wire is insulated with an enamel coating which has to be scraped off before you can attempt to solder it. I couldn't tell from your photo if you had scraped it or not when you soldered it, my guess is yes because when you powered it up, it got hot. Try checking the continuity to ground, my guess is you will find that the winding is shorted. At this point, you have nothing to loose. You might try to wind a new relay coil. Carefully unwind your burned up one and rewind with enamel wire of similar wire size. I usually harvest my wire from old relays or other power supply transformers I no longer need.
Oaker57 (12-22-2016)
Yes I scraped the wire back before soldering, but after reconnecting on the work bench, the coating started to bubble as it rapidly overheated.
I have never actually rewound a relay before, but at this point have nothing to lose I suppose. I assume you must count the number of windings in the old, and keep it the same with the new wiring. Is enamel wire easily found, I have to admit I'm not familiar with it.
I just wish there was somewhere to get a replacement relay, but as I said in my original post, nothing turned up after my research, although a part number or size would have probably made a difference.
Thanks again for the suggestions....
Received 1,919 Likes
Re: enameled wire, I assume that it is still available, but probably not available at the corner hardware store anymore. It used to be, and many moons ago I rewound old relays. I know of lots of guys rewinding old motor armatures, but I never tried that.
Given that you're deep enough into to it to have tried to fix it yourself so far, what do you have to lose by trying to rewind it?
Good luck, and be sure to let us know how it goes.
Still hoping someone may know where I can find a relay replacement......
For $150 Clock Works will put an entire, new OEM Borg movement in your clock....they did it for my 63 just prior to judging. What's your time worth to you ?
Bottom line is I just want to have a working clock, having the ticking second hand would be preferred, but if a sweeping one gets it done, then I will just live with that.
Happy New Year
Thanks Frank, I can do that, or as I mentioned, just go with the quartz replacement. My car was not all original when I got it, so judging is not an issue for me. It's more that I've had my hands in just about every part of restoring it and I just enjoy being able to fix it if I can.
Happy New Year
Happy New Year
I put a quartz clock in mine and I have never looked back. Well worth it not to hassle with taking out the clock to fix it. Plus its almost guarantee if you fix your original you will be pull out of the car at sometime again to fix it..,,
Oaker57 (01-02-2017)
Phil M.
I converted the 63 clock BACK to the Borg (resistance is futile, you WILL be assimilated) mechanical OEM configuration from quartz for judging last year. I subsequently added a small invisible 12V relay behind the dash to turn it on/off via a key fob remote. The clock is only on for judging or shows with picky spectators. Took about 25 minutes to install and didn't butcher any original wiring.
If you price out what 63 dash clocks are going for then any way you can avoid damage/loss from shipping them around the country for repairs is a boon.
According to Clock Works the relay will extend the lifespan prob enough to eclipse my own.
Check out Instrument Services, Inc. tel. 1-800-558-BORG. They bought out Borg a few years ago and will either rebuild, convert, or sell parts for your clock. I bought some replacements gears from them last year. They are very helpful also (which is rare these days).
Phil M.
Phil M.
Happy New Year,
Mark
Received 1,581 Likes
St. Jude Donor '20-'21-'22-'23-'24
Steve
Uh - if its that EXACT same item Steve its max current rating is 15 amps; not sure what your SPAL fan may draw but you might want to check...
Thanks for pointing out the potential problem. I will make sure to check the current on that line to verify before I do anything.
Take care,
Steve
Hey OAKER, did you get your clock fixed? I also "touched" mine way back when. My hand turning stem just slipped so I took it apart and "stuff happened" from there. So much for that exercise and a new one was ordered. I'll never use this one and you're welcome to it. PM me your mailing address and I'll wing it off to you. This ones out of a '65 but I think they are the same..........zeeker
Oaker57 (01-06-2017)
Phil M.
Phil M.
They do have lots of other parts available, and they do sell a quartz replacement that they manufacture, and at a good price....
So when all else is exhausted I will call them back for the replacement
Thanks again for the lead.....
Regards,
Mark
Update: spoke with Instrument Services and although very helpful, they unfortunately do not sell the relay's.
Regards,
Mark
Regards,
Mark
Oaker57 (01-08-2017)
I pulled my clock from my '64 Coupe and updated to quartz, but then I pulled that and re-installed a totally rebuilt '64 mechanical clock (pricey). I have all the parts from my original clock if you're interested, as far as relays go I found www.obsoleteparts.com to be very good, I bought a horn relay and AC relay for my my '64 that were new in the box.
PM Sent....
