still have starter problems
My 67 327-350 hp still has starter problems I have 2 volts to s terminal and 4.8 volts to starter side, battery shows 12 volts any suggestions? Does power go thru
the voltage regulator? Hopefully someone might have suggestion to try. THANKS Jack
Received 6,530 Likes
C2 of Year Finalist (track prepared) 2019
Jack,
It would help to have information about how you are making those measurements. Under what conditions do you see 2 Volts on the S terminal? And same question regarding the 4.8 Volt reading. Also, are you seeing 4.8 Volts on the large solenoid terminal to which the battery cable connects? And (I bet you see this one coming) what are the conditions during which you see 12 Volts at the battery?
No, starter current does not go through the Voltage regulator. My hunch is you've got a loose connection.
Jim
Jim
Jack,
Jim
Jim
Received 6,944 Likes
2015 C2 of Year Finalist
have you checked the fuesable links
Received 1,534 Likes
What have you replaced or worked on prior to the problem starting? Starter? Solenoid? Cables? Alternator? etc.?
12v at the battery under the load of the starter while trying to start sounds like a bad positive or negative cable or cable connection from the battery to the starter and/or ground. The battery should be about 12.4 volts with no load. I would expect the battery voltage to drop a couple of volts under starter load, but no more than 3 or 4 volts.
Put a jumper cable between the negative battery clamp and an engine ground. Try to start it again. If no change, put a jumper cable between the positive battery clamp and the large positive post on the starter (careful not to short it out). Try to start it again. That way you have ruled out a bad cable. A bad connection in the solenoid on the large battery connection could also be breaking down under load.
Are the headlights bright with the engine off or dim? Anything else quit working with the beginning of the starter problem? Ammeter? Radio? etc. when the key is in the on position?
starter problems
Glad it worked for you. Pass it along to the young pups to keep the classics alive.
Ron
Vette now starts
R66, I ended up having to replace the ground cable also starts fine now thanks again. I am also an old fart
No insult intended, as our house is full of home to two OLD FARTS and hundreds of real farts every day. We just have to remind our fellow OLD FARTS of the things they forgot in the last 1/2 century or so. More important is to pass on what you know to others, especially the young Einsteins of our hobby.
Glad to help you out, it's your turn.
Ron
