1963 front upper control arm bushing
Old 01-16-2017, 10:41 PM
chrismoore701
chrismoore701's Avatar
Default 1963 front upper control arm bushing
I lost the front upper bushing on my passenger control arm. i am guessing I have to pull the whole thing out. I have everything out except the control arm. Ordered the bushing tonight. If I pull this out and keep the shims in order will I have to go back for an alignment? Just had it aligned within the last two years.
Old 01-16-2017, 11:54 PM
pop23235
pop23235's Avatar
Received 1,022 Likes on 682 Posts
Please define "lost the bushing". Rubber failed? Bolt missing and bushing actually not there?
That will help with answer. I'd be surprised if the inner and/or outer steel part of the bushing is gone.
Old 01-17-2017, 08:00 AM
chrismoore701
I changed out the bushings last year and apparently, I say apparently because I do want to believe it, but I forgot to tighten the bolts. Driver side was finger tight, passenger side is gone. Bolt, retaining washer, and rubber part of the bushing. Sleeve is still in the control arm. Luckily I only put about 50 miles on the car last year.
Old 01-17-2017, 08:59 AM
Frankie the Fink
Frankie the Fink's Avatar
Received 7,082 Likes on 4,736 Posts
Army
Seriously ? You're worried about a $70 alignment ?
If it had been my alignment guy he would have spotted that loose bushing in two seconds and told me about it.
Replace the bushing, take it to an 'old school' alignment shop and have him look over your work..you were lucky once, maybe not twice..
Old 01-17-2017, 09:13 AM
pop23235
pop23235's Avatar
Only way I know to get the outer sleeve out and a new bushing in without damage is to remove the A arm. That would require alignment. This may be done without removal, but The bushing is pressed into the A arm, and I don't see how to do that in place.
Old 01-17-2017, 02:19 PM
chrismoore701
So this seems to be a very interesting bit of information. I recently replaced all the rubber with polyurethane bushings. Apparently they are known to cause the bolt to back out. I plan to go out and buy all new bolts and lock washers and use some lock-tight. Anybody else experience this issue? Anything else I should do? I just did the same thing on my 79 Chevy truck, will be checking and replacing all these bolts as well
Old 01-17-2017, 04:39 PM
leif.anderson93
leif.anderson93's Avatar
Received 3,096 Likes on 1,865 Posts
I recently had an upper control arm bushing retainer bolt back out, as well. Nothing catastrophic, as the bushing is press fitted in. I removed all four upper bolts (none were torqued correctly), applied Loctite 242 and re-intalled bolts and lock washers...torqued to 40 lb ft. It is my understanding that this is an item you need to check occasionally, if you drive your car (not a garage star). The Loctite should prevent future back-outs but I will still check them semi-annually...too easy not to
Old 01-17-2017, 06:10 PM
GUSTO14
GUSTO14's Avatar
Received 1,962 Likes on 1,283 Posts
Did the poly insert only come out, or did the outer sleeve or inner sleeve also come out?
If the outer sleeve is still in the control arm, I would contact the manufacture of the poly bushings you previously installed and try to purchase a couple of replacement poly bushings. I would use a generous amount of polyurethane bushing grease and see if you couldn't push the new bushing back into the control arm.
It would be helpful if you could post a picture of what you are looking at so we might give you more relevant advice.
Good luck... GUSTO
Old 01-17-2017, 06:23 PM
MOXIE62
MOXIE62's Avatar
What are you guys driving on, old cobble stone roads. I've never had any of that to happen. Locktite seems like an over kill if you have torque all your bolts correctly.
Old 01-17-2017, 06:44 PM
chrismoore701
Old 01-17-2017, 06:48 PM
chrismoore701
The inner sleeve and bushing are gone. I went to the alignment shop and he agreed that the poly bushings can cause the bolt to back up because the bushing is not fused to the sleeves. He gave me a retainer washer and offered to give me a deal on the alignment. New bolts. Lock washers and lock tight or going on. I can't remember where I got the bushings. Ordered a new bushing yesterday. Coming tomorrow
Old 01-17-2017, 07:56 PM
leif.anderson93
Maybe, but it can't hurt. Better safe than sorry...know what I mean
Old 01-17-2017, 08:01 PM
project63
project63's Avatar
The inner sleeve and bushing are gone. ....
Looks to me like the inner sleeve is still on the shaft...
To 1963 front upper control arm bushing
Quick Reply: 1963 front upper control arm bushing
