Heater core choices / quality issues / opinions sought
About 12 years ago the heater core, (non ac car) left a few drips of coolant in the footwell. Not much of a leak but a leak nonetheless. To buy time and to prevent a footwell coolant flood I put a shut off valve on the heater hose intending to fix it later on that year but never got to it.
I want to make the repair this winter.
The reproduction cores are anywhere from $55 to $100
I can also find nos AC Delco cores but they are triple the cost or more.
I can also have the original re-cored also more costly than repro cores.
Are these repros decent or will I be changing the heater core in a few years if I buy one of these asian or mexican products ?
Is it best to just buy the pricey nos AC Delco?
Anyone have any problems with the repros?
Opinions on the best option here would be appreciated.
Which ever one you end up purchasing...have it checked out/pressure tested before you install...
phil2302 (01-19-2017)
Received 6,943 Likes
2015 C2 of Year Finalist
I would have your original re-cored. So you know it will fit
Thanks fellas.
My fear is a repro could initially pressure test fine but maybe fail prematurely.
The $60 repro sounds attractive but it really isnt the cost so much as the idea of having to do it again.
My ability to work in tight spaces is going down hill fast due to R/A
I am leaning toward having the original recored but want to take it out and examine it first. If I dont like what I see I will buy a NOS AC Delco.
If anyone has used a reproduction that failed please chime in.
Received 1,843 Likes
FWIW, I put a new heater core in my '63 about ten years ago. I replaced the one in it because it was the original core. It came from NAPA and at that time, I think they were made in Mexico. The thing lasted about a year and then it started dribbling in the foot well. A half bottle of Barr's has fixed the problem for me nicely. Minimal expense and trouble.
Melting Slicks<br><img src="/forums/images/ranks/3k-4k.gif" border="0">
Received 1,946 Likes
I bought a repro about 13-14 years ago and it lasted about 2 years. I bought another one and it has been fine for 11-12 years. Pretty much a crapshoot on the repros.
I put a Repro in my '65 last year and the outlet pipes were bent just enough different that it took a lot of screwing around to get it to fit "close enough". If I had it to do over, I'd have my old one re-cored.
phil2302 (01-20-2017)
I think I have decided to stay away from the repros.
Did you get any quotes for the re-core?
If it is close in price I may just go with a NOS AC Delco.
