1963 horn continuously blows
Old 01-23-2017, 10:26 PM
chrismoore701
chrismoore701's Avatar
Default 1963 horn continuously blows
i think this is the first time I have hooked the horn up in about 30 years. It works. But when I push the horn it will not stop blowing. I unplug the relay and it resets until I push the button again. I am sure the relay is sticking. But is there a way to fix this? Or just replace it? More interested than anything
Old 01-23-2017, 10:31 PM
65GGvert
65GGvert's Avatar
Received 3,220 Likes on 2,302 Posts
If it's the same as a 66, I took the cover off one and filed the contacts flat so they didn't stick from the arc of contact. While you're in there check to make sure the spring that pulls the contacts apart is connected and working properly.
Old 01-23-2017, 10:33 PM
66jack
66jack's Avatar
Do the 63's have the ground strap on the rag joint?...if so...run a test wire from one end to the other to check... it could be broken into...dead short..
Old 01-23-2017, 11:06 PM
65GGvert
65GGvert's Avatar
If the wire breaks in two, there would be an open and the horn wouldn't blow at all.
I would try tapping on the horn relay when it sticks and see if it stops. It may just be a weak spring. I may also that you have a high resistance short to the black wire between the relay and the horn button to keep the relay closed until the voltage is removed and the current isn't enough to activate it again until you press the button.
Old 01-24-2017, 06:33 AM
Frankie the Fink
Frankie the Fink's Avatar
Received 7,082 Likes on 4,736 Posts
Army
63s have the rag joint ground strap...it would be a long shot that that is the issue...
Old 01-24-2017, 08:12 AM
chrismoore701
I replaced the rag joint years ago with a universal joint. Right now the horn button is broken so one is on order. So to test all I am doing is grounding the plunger to the shaft of the column.
Old 01-24-2017, 08:48 AM
65GGvert
65GGvert's Avatar
Either the relay points are sticking or you are not completely removing the ground to the black horn wire
Old 01-24-2017, 10:37 AM
chrismoore701
Would jumping the rag joint with a wire work as a ground?
Old 01-24-2017, 01:27 PM
65GGvert
65GGvert's Avatar
Connecting a wire across the rag joint would work if your ground was broken and the horn wasn't working, but what you have is a horn that's working too much, a rag joint won't cause that. See my last post
Old 01-24-2017, 02:11 PM
chrismoore701
Another question is I only have one horn hooked up. Would that cause the relay not to work. Not enough current being drawn
Old 01-24-2017, 03:24 PM
65GGvert
65GGvert's Avatar
No.
Old 01-24-2017, 06:19 PM
chrismoore701
Bought a new relay $17 at auto zone
Old 01-24-2017, 06:37 PM
65GGvert
65GGvert's Avatar
Did it correct your problem?
Old 01-24-2017, 08:17 PM
chrismoore701
Pick it up tomorrow
Old 01-25-2017, 01:49 PM
ejboyd5
ejboyd5's Avatar
The suspense is killing us.
Old 01-25-2017, 03:44 PM
chrismoore701
8:00 tonight
Old 01-25-2017, 08:09 PM
chrismoore701
We have a working horn folks
Old 01-25-2017, 08:15 PM
rene-paul
rene-paul's Avatar
Yes!
To 1963 horn continuously blows
Quick Reply: 1963 horn continuously blows
