[C2] Need Source Recomendations for New Exhaust Manifolds
Tigershark3 (02-24-2017)
I'm going to convert the mount to a more correct one for my '66 so that the manifolds you show will fit. Question is: I need 2". Do you know if these Dormans you provided a picture of are 2"
Thanks a lot for taking the time to help me with this... I'm learning slowly but surely.
Received 1,843 Likes
No it's an earlier mount like this:
1966 coupe... The exhaust manifolds are in pretty bad shape. One of my winter projects is to replace these with new. As near as I can tell the casting numbers are 3747038 and 3749965. Anyone have good luck with new imported castings? Most of the used ones I see on eBay are in pretty bad shape.
Thanks in advance
Greg
Thanks in advance
Greg
Is your alternator mounted onto the right side 3747038 manifold? If so then the wiring harness was modified to mount the alt on the right side (normal 1966 alt mount is on the left side).
If that is the case, then you need a 1964-65 style upper mount bracket. There is also a steel piece that mounts between the right side manifold and the alternator for the right side mount.
With the part numbers that you have, the alternator should be mounted on the right side.
If you want to mount the alternator on the correct, left side, then you should buy the proper manifolds for a 1966 Corvette small block, the previously posted brackets, and you will have to modify your engine harness back to an original 1966 configuration.
Tigershark3 (02-25-2017)
The 674-502 looks like 2" to me----and has the pig ear mount:
For the right side you could run another 674-502 and cut the mount off----& grind to finish. Or use a 674-501 with the smog tube plugs.
501:
501:
For 1966-67, the alternator is mounted on the driver side and the exhaust manifold mounting provision has two threaded holes that run parallel to the crankshaft. The basic appearance is like the repro unit in the photo below. This manifold is different from the earlier versions that mounted the alternator on the passenger side.
I have all the correct casting numbers on file but I'm away from home right now. Let me know if you want me to look them up when I get home on Sunday.
See post 21.
Sounds to me like the OP has the wrong manifolds on his car now but I can't tell from the posts.
To add to Tripleblack's comment, there are at least two styles (maybe more) of C2 exhaust manifolds with provisions for an alternator mount.
It's not clear from his posts whether it's mounted on the right or left side; however, I have to assume that it's mounted to the right side since his manifolds are pre 1966. His casting numbers were enumerated in an early post.
Whatever manifolds he decides to get, he has to buy 2" manifolds because his exhaust head pipes are 2"................ironically, and I suppose, luckily "correct" for his 1966 small block, although I don't get the impression that the OP cares about that.
Another item that comes into play, is whether or not the engine installer used a 1966 engine harness, or some other. If the 1966 harness was used, then it had to be modified to accept a right hand alternator mount.
The OP is giving vitals in "drips and drabs". From what I have been able to sleuth together based on the very sketchy information, is that his alternator is mounted on the right (OP: that means "passenger" side) and whatever engine harness is being used was cobbled to make it fit in his 1966 model, unless he used a 1964-65 engine harness.
If the previous paragraph is true, then the OP would be wise to buy the proper Dorman replacements for a 1965 327/250-300 (2"). This would permit him to use his current alternator brackets, as well as his current wiring harness and head pipes.
He has a hodgepodge. An 350 engine from a later model year, and exhaust manifolds from prior to 1964. He has a 1966 car.
Appreciate all the comments...
It is a hodgepodge that I'm trying to correct. The alternator is mounted on the driver's side with early manifolds with the 350 replacement engine. Dorman has these manifolds that are 2" (I called them to verify) and I believe are correct for a '66 (674-500 and 674-501). I'll need to get another alternator mounting kit to go with the new manifolds but that's ok
Some of the new aftermarket A/C systems are terribly efficient and not too difficult to install.
Good luck... GUSTO
