fuel pump install
Old 02-08-2017, 02:34 PM
Thomas M
Thomas M's Avatar
Default fuel pump install
Well spring is upon us in Texas and I started doing some more wrenching on the project car. This thing has been a hodge podge of parts. I have replaced all the rotors,calipers and pads. Noticed a "knock in the bottom in the engine and through the interweb and friends , am leaning to replacing the fuel pump. It like other things I found on this car are not original. Fuel filter was deleted by the previous owner.I will be installing a new one with the new carb. Anyone know of a short cut to install fuel pump without having to fight that pushrod for pump?
Old 02-08-2017, 04:11 PM
Bluestripe67
Support Corvetteforum!
Bluestripe67's Avatar
Received 2,125 Likes on 1,464 Posts
There is a bolt at the front of the block parrell to the rod. Remove it, rotate the engine enough for the rod to go full in, replace the bolt with a slightly longer one so it snugs the rod in place. Install the pump, remove the long bolt, put some gasket sealer on the short bolt, tighten, your done. Dennis
Yellow65FI (08-03-2023)
Old 02-08-2017, 04:15 PM
GCD1962
GCD1962's Avatar
Rod is full in at TDC
Old 02-08-2017, 04:45 PM
Thomas M
Thomas M's Avatar
Thanks for the info, I really wanna be cruising this thing this spring.
Old 02-08-2017, 07:42 PM
Desert Nomad
Desert Nomad's Avatar
That bolt hole your talking about is just on the small blocks, correct? I don't see it on the big blocks at least not on mine.
Old 02-08-2017, 08:05 PM
Bluestripe67
Desert Nomad you may be on to something and the OP didn't mention what engine he had. Well if that is true, then he can use w/bearing grease. Lets wait and see. Dennis
Old 02-09-2017, 06:29 AM
59BlueSilver
59BlueSilver's Avatar
2023 Restomod of the Year Finalist
I think you mean perpendicular to the rod.
Old 02-09-2017, 10:05 AM
Bowtyeguy
Bowtyeguy's Avatar
I agree with the bearing grease to keep it up . Wont hurt anything.
Old 02-10-2017, 10:56 AM
plaidside
plaidside's Avatar
Received 1,120 Likes on 550 Posts
Here are some pictures of the bolt, rod, long bolt and it installed.
As stated it would better to get the engine at TDC with both valves closed though not necessary.
Joe
Here is the bolt that needs to be removed:
This is the bolt removed:
Here is the bolt I use, note I rounded off the end:
Bolt installed, do not over tighten, just enough to hold the rod:
Be very careful to get the pump arm under the push rod and not on top of it:
Old 07-07-2017, 01:15 PM
BigT-65
BigT-65's Avatar
This is great information. I found the bolt hole right where your pictures show but mine has no bolt in it. What size would that bolt be, diameter, thread, etc so I can go get one. About 4 years ago I had a local shop replace my fuel pump they must have left it out. You would think oil or something would leak out of this hole if no bolt is in it.
Old 07-07-2017, 01:46 PM
MOXIE62
MOXIE62's Avatar
3/8" course thread. I used a 2" long carriage bolt to hold rod up. Other lengths will probably work but I wanted to make sure there were enough threads on bolt to keep rod up.
Old 07-07-2017, 03:03 PM
BigT-65
BigT-65's Avatar
Thanks for your reply. I found a bolt in my bolt collection that did the job. Has anyone got an thoughts on the fact that the bolt was missing from my engine. I have not had any oil leaks around there. I am concerned and puzzled.
Old 07-07-2017, 09:39 PM
BigT-65
BigT-65's Avatar
What would be the consequences of that bolt not being in place? Mine has apparently been out of there for 4 years.
Old 07-07-2017, 10:13 PM
MOXIE62
MOXIE62's Avatar
I would think at least a slight oil seepage.
Old 07-07-2017, 10:37 PM
Powershift
Powershift's Avatar
Received 1,681 Likes on 1,307 Posts
Another option for the temporary bolt to hold the fuel pump rod when changing out the pump is to use a brass bolt......it will not nick or damage the fuel pump actuating rod.
Permanent bolt should be steel.
Larry
Old 07-07-2017, 10:41 PM
MOXIE62
MOXIE62's Avatar
Larry
Hand tighten bolt is enough pressure to hold rod up. But if you put a wrench on it then yes, brass
Old 07-07-2017, 11:44 PM
Kerrmudgeon
Kerrmudgeon's Avatar
Received 4,583 Likes on 2,157 Posts
C1 of Year Finalist (appearance mods) 2019
Shouldn't have caused any damage by not being there. The rod rides on the cam and fits pretty snug in the casting hole. You probably got a little oil seepage, and maybe a little dirt from road grime in there but that depends where you drive it I guess. Someone left it loose and it fell out I'm thinking.
If you use the heavy grease method make sure your engine is stone cold when you do. AND....sometimes it's easier to remove the bolt through the motor mount and jack the engine up on that side an inch or so to get at those bolts.
To fuel pump install
Old 07-08-2017, 12:36 AM
BigT-65
BigT-65's Avatar
Thanks for the replies. I feel better about the bolt being missing. There will be one in there after this job.I might look into jacking the engine up a little bit. Anything to make getting the new pump in there easier.
Old 07-08-2017, 06:40 AM
Chuck Gongloff
Chuck Gongloff's Avatar
Unless you run into something like this.
65 327 block in my 37 Chevy.
Bosses there... nothing tapped. I ran into this a few months ago when I replaced the fuel pump. Had never seen that before in a SB Chevy.
Old 07-08-2017, 09:08 AM
Mike C#2
Mike C#2's Avatar
Interesting. I don't think I've ever seen one that didn't have those holes tapped? I replaced the fuel pump on my '94 Malibu ski boat last month and found that the holes on the 265hp 350 are blind. Made doing the pump much more difficult with a telescoping magnet and contortions!
Quick Reply: fuel pump install
