C1 Axle ratios and Gear Ratios - CorvetteForum - Chevrolet Corvette Forum Discussion
C1 & C2 Corvettes
General C1 Corvette & C2 Corvette Discussion, Technical Info, Performance Upgrades, Project Builds, Restorations
Old 02-10-2017, 09:27 PM   #1
62 corvette nut
CF Member
Default Axle ratios and Gear Ratios
I'm "Corn Fused" (as my uncle Bill used to say. I have a 62 with a 327 - 340 HP - 4 speed positraction. The Corvette servicing guide (ST-12) on page 14-2 lists 3.36:1 regular ratio but it lists 6 different Positraction ratios. How do I determine what I have?
Also in the transmission section page (14-17) it lists 2 ratios for each of the first three gears. Again how do I tell what I have?
I know someone out there has the answer or can tell me how to calculate it. All help greatly appreciated, i've owned the car since 1968, but never payed much attention to the gearing, now i'm curious.
62 corvette nut is offline   Reply With Quote
Old 02-10-2017, 09:52 PM   #2
OC-1
CF Senior Member
OC-1's Avatar
see this one of many threads
http://www.corvetteforum.com/forums/...end-gears.html
also if rear is original it will have a cast date code and part# on drivers side on lateral front facing surface
opposide side there is a stamped code that reveals axle ratio. very difficult to see. scrub clean to see. find codes for vette on differernt vette websites.
codes for 62 chev may not match up with codes for 62 vette.
rear gears could have been changed so follow direction in suggested thread.
trans could be wide ratio
OC-1 is offline   Reply With Quote
The Following User Says Thank You to OC-1 For This Useful Post:
62 corvette nut (02-12-2017)
Old 02-11-2017, 10:37 AM   #3
SWCDuke
CF Senior Member
Assuming the speedometer gearing is correct for the installed axle.
In forth gear axle ratio = revs @ 60 / 760.
All 340/360 HP engines ordered with the optional four-speed received the close ratio version (2.20:1 first gear).
Duke
SWCDuke is offline   Reply With Quote
The Following User Says Thank You to SWCDuke For This Useful Post:
Old 02-11-2017, 11:59 AM   #4
hope2
CF Senior Member
Simply turn rear wheels one revolution and count revolution of driveshaft. Revolution of driveshaft equals the ratio. Thus driveshaft turns 3.7 times, ratio is 3.70. This only works with positraction.
hope2 is offline   Reply With Quote
The Following User Says Thank You to hope2 For This Useful Post:
Old 02-11-2017, 02:48 PM   #5
ohiovet
CF Senior Member
Support Corvetteforum!
C1 of Month Finalist 2016
ohiovet's Avatar
Try what hope2 described.
I believe that typically the car with a close ratio trans (2.20 first gear) had a 3.70 rear gear. The 2.20 first gear and a 3.36 rear would be hard on the clutch and the driver.
Difficult to get the car moving.
ohiovet is offline   Reply With Quote
The Following User Says Thank You to ohiovet For This Useful Post:
Old 02-11-2017, 11:52 PM   #6
HilltopClassicCars
CF Senior Member
HilltopClassicCars's Avatar
Quote:
And if you don't have positraction differential, lock one rear wheel in place and turn the other rear wheel exactly two complete revolutions while counting how many times the pinion shaft/driveshaft yoke revolves and that will give you the gear ratio.
HilltopClassicCars is offline   Reply With Quote
The Following User Says Thank You to HilltopClassicCars For This Useful Post:
Old 02-12-2017, 05:04 AM   #7
wmf62
CF Senior Member
St. Jude Donor '07
wmf62's Avatar
Quote:
I believe that typically the car with a wide ratio trans (2.20 first gear) had a 3.70 rear gear. The 2.20 first gear and a 3.36 rear would be hard on the clutch and the driver.
lol... (2.20, CLOSE ratio...)
Bill
wmf62 is offline   Reply With Quote
The Following User Says Thank You to wmf62 For This Useful Post:
Old 02-12-2017, 03:17 PM   #8
tuxnharley
CF Senior Member
tuxnharley's Avatar
True that - that's the way my '67 was built. OTOH, I lived with it that way for about 35 years, until I put in a Tremec TKO 500 with a 3.27 1st gear and a .67 5th!
tuxnharley is offline   Reply With Quote
Old 02-12-2017, 10:03 PM   #9
62 corvette nut
CF Member
Default Have You installed the TKO 500 in your 62?
If you have how do you like it? What are the Pros and Cons? Who installed it for you, I'm just down the road from your location. Approx. cost to install.What about the clutch (Hydraulic or Manual, Why?
Thanks,
Marty
Old 02-16-2017, 08:43 PM   #10
62 corvette nut
CF Member
Quote:
Bill
Bill I tried to send you a PM, obviously i'm doing something wrong.
Bill,
I spoke with 'Frankie the Fink" on the phone this afternoon he suggested I call you about the 5 speed transmission that you installed in your 62. He says it was from Silver Sport and that it shifts slicker then the Tremec TKO 600. I think he said it was an "RS" model. What is different about this transmission versus the TKO 600.
I am going thru the thought process of installing a five speed in place of my T-10 "Rock crusher".
How long did it take to install? What was the price comparison between the two kits? Thanks for your help.
Marty
Old 02-16-2017, 09:45 PM   #11
DZAUTO
CF Senior Member
C1 of Month Finalist 2015
2.20 is a CLOSE ratio
2.56 is a WIDE ratio
DZAUTO is offline   Reply With Quote
Go Back   CorvetteForum - Chevrolet Corvette Forum Discussion >
Reload this Page
  • [C1] Axle ratios and Gear Ratios
    Related Topics
    Thread Thread Starter Forum Replies Last Post
    Gear ratio swap questions? improvements, mpg, noise, cost? Suns_PSD C6 Tech/Performance 1 02-18-2016 08:02 PM
    Best gear ratio for 1/4 mile time in A4? 2001 C5ster C5 Tech 7 04-22-2015 05:43 PM
    Rear Differential Gsmit72 C3 Tech/Performance 3 03-22-2015 11:56 PM
    Changing rear end ratio - options?? R6T7 C1 & C2 Corvettes 27 03-09-2009 03:22 AM
    1sr gear ratio ? Gordonm C3 Tech/Performance 46 02-23-2007 05:37 PM
    Search this Thread:
    Click for Advanced Search
    Posting Rules
    You may not post new threads
    You may not post replies
    You may not post attachments
    You may not edit your posts
    BB code is On
    Smilies are On
    [IMG] code is On
    HTML code is Off
    Trackbacks are Off
    Pingbacks are Off
    Refbacks are Off
    Forum Jump
    • Ask a Question
    What's your question?
    Send
