VHT Flameproof paint
Received 6,528 Likes
C2 of Year Finalist (track prepared) 2019
Well, I'm curious now. On advice from another forum, I wanted to coat a set of manifolds with some kind of coating to look like cast iron. It was recommended I use Rustoleum copper metallic spray paint. Spray the manifolds and bake them in an oven for two hours at 400*
They went in the oven looking like copper and came out looking like copper. No change. Looked almost like FTF's manifolds. I was told the heat would changed the copper to a cast iron gray. Didn't happen. So just to make sure I had enough heat on them, I put a torch to them and got them very hot. Still no change or discoloration.
Where did I go wrong?
I don't know. The only requirement for the copper paint I ever heard was that it have a very high metallic content. My memory is the recommendation was for it to be 7% metallic or greater.
Do you still have that Rustoleum can so you can check?
Received 1,843 Likes
I have it right in front of me but I don't see anything about copper content.
This is supposedly the same paint written about in a Drive Line article some time back about blacking out manifolds.
The type paint is noted in my post above. Click on the Amazon symbol.
I suppose the MSDS might reveal the copper content.
