[C2] Richmond 5 speed and slip yoke advise please
Hi I'm ordering a driveshaft for my '67 w/ a Richmond 5 Speed trans and found that I need to have the slip yoke to be 3/8" or less off of the tail housing for it to clear the transmission tunnel but was told by the shop that at least 1/2" is needed for the install. Has anyone install 1350 sized slip yokes in the car with less than 1/2" clearance?
I would think it would be ok in our application since we do not have a floating rear end. However it may make it impossible to get the driveshaft into the yokes without moving the engine forward or the rear end back.
I am slightly behind you. I am putting a Richmond with the Moser 1350 yoke in my 69. Am wondering if it will fit.
St. Jude Donor '05, '09, '15
Which RG 5spd are you installing? The non-OD RG uses a stock driveshaft with a Corvette T400 yoke. Have one in my 65. Then use a combination u-joint to the stock shaft. The u-joint for the yoke is 1330 and the shaft is a 1310. Half shafts are 1350.
http://www.dennysdriveshaft.com/p377...t_3_732_x.html
Tom
The 69 may already have the 2 1/2 driveshaft and already use 1330 joint stock. The combination joint is not needed.
Tom
At trans yoke before fiberglass work
Fiberglass area at trans tunnel
Not a great photo I showing how hot the curing fiberglass got.
At rear seat belt reinforments
Yoke at rear end photo
1. have more than 1/2 inch clearance between end seal and yoke and modify tunnel.
2. have 3/8 inch clearance and take chances on the install, and could it be possible to find enough clearance by rotating the DS so it would lear the flange from the diff? If nothing works then move rear end out of the way, install DS, then put rear end back.
Doesn't option #2 appear to be better?
That is a good point on which Richmond it is. Mine is the 4+1. It seems like the guys with yokes not fitting the tunnel, are the Overdrives that stick farther back into the tunnel. I assume yours is a Muncie Dave? What made you need the removable Crossmember? I definitely want to run 1350 yokes on both tranny and rear end. Thanks for the pics. Wonder if the 66 and 69 tunnel are the same.
To the op, don't know which to do. It might be a real pain in the *** to move that differential but maybe since it won't have to be done very often. Is yours running into the parking brake stuff? And which 5 speed do you have?
That is a good point on which Richmond it is. Mine is the 4+1. It seems like the guys with yokes not fitting the tunnel, are the Overdrives that stick farther back into the tunnel. I assume yours is a Muncie Dave? I definitely want to run 1350 yokes on both tranny and rear end.
Bruce, don't know which to do. It might be a real pain in the *** to move that differential but maybe since it won't have to be done very often. Is yours running into the parking brake stuff? And which 5 speed do you have?
Tom
Tom, yes you are right. 69 4 speeds are 1310. Turbo 400's are 1330. My diff is currently with Tracdogg and he is building me a heavy duty 10 bolt with the 1350 yoke. So with the 1350 trans yoke I will order a driveshaft after getting it all in the car. Sorry for the confusion.
Bill
Bill
My trans is the 1:1 Road Race version. And as to moving the diff, maybe the bolts will only have to be loosened and allow some play for the DS to drop into place? It may not be that bad, I just need to gather up enough courage before ordering that DS.
Bill
Bill
No worries I am easily confused.
Tom
Tom
It is a Autogear M22, so yes just like a regular Muncie my trans tunnel is pretty straight back so another 1" or 2" farther back I would still need to do the fiberglass work. I have no idea if your car is similar as my C2. In order to get the driveshaft past the rear cross member and the studs for the seat belt reinforcements you need to angle it back. The angle in which you need puts the driveshaft in conflict with the trans cross member. If I had to do it over I'd do a 2 1/2" or 2 3/4" O.D. driveshaft. That extra little room is very helpful. Obviously the 1350 joints are the same regardless of what O.D. driveshaft you use.
Ah gotcha, thanks Dave. I don't know if you remember me Dave, but I bought a 62 340hp intake from you. You had just pulled the body on the 66 when I was there. Glad to hear you got it done!
Bill
Bill
Yes I remember. The car is totally done and came out really nice. Did everything, body work, paint, interior I mean everything in my garage. Go to my photo album page on here you can see for yourself.
With close to 600 HP/Ft-LB, I was told by a couple places regular C2 DS's they sell won't be able to handle the power. Here's a picture of the BEAST on the left w/ 275's in the front and 315's on back....
I'm ordering a 2.5" DS w/ .12" thick wall steel shaft for the car, just want to triple measure before ordering.
Oh and what about shifting the trans a little to the driver's side as the yoke is only rubbing on the passenger side of the tunnel? After shifting, would the DS still within alignment angles allowed?
Hi Sky,
Tom
