master dave
Received 5,010 Likes
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17-'18-‘19-'20-'21-'22-'23-'24
Have the list of incoming messages in front of you. At the far right had side is a small box on each line. Click on the ones you don't want, and a check mark will appear.
Down at the bottom right it will say "Move to..." There is a small triangle there, click on that and instead of "Move to", select "Delete". Click on that and you will purge them.
Then up at the top center select "sent messages" and repeat.
I may not have everything exact but hopefully that will get you there.
Location: About 1100 miles from where I call home. Blue lives matter.
Received 5,331 Likes
If you want to ask Dave a question, its much more efficient to send him a PM rather than hope he happens to see this thread.
