6 quart oil pan on 365 sphp 365
Cruise-In III Veteran
Assuming the motor's in the car, in addition, you will have any easier removal/install if you first rotate the motor so that the index line on the harmonic balancer is at the 5 o'clock position as viewed from the front of the car (counter weights on crank will then be on top giving you more clearance)
Jim
In God We Trust!
Jim
In God We Trust!
