[C2] 67 Turn Signal question
So my turn signal lever is hanging limp...doesn't work. Do I need a new "Turn-signal switch" ...or just a "cam" or a "doorman"...I don't think my harness is bad, I think something plastic broke.
Received 6,943 Likes
2015 C2 of Year Finalist
Before ordering any parts I would remove the steering wheel hub and have a look see
Can you get the lever to stay in the up position (right turn signal)? If so, there is a red plastic spring and catch assembly that is probably broken. I had this problem with my '67 and had to replace that part. The plastic catches are easily broken with time due to plastic degrading with heat, etc.
Phil
Phil
There are a couple of options when replacing the switch – either remove the wires from the connector end and thread the harness, or remove the steering column to thread the harness and connector in one piece. I pulled my column for other reasons but many find it a lot of extra work.
The pics below are what I found when I pulled mine about five years ago and an illustration describing removal of wires from the connector ('67's have a wider one piece connector with more wires).
Thanks guys, and thanks for the pic Mike67NV. I'm guessing that the screw that holds my lever somehow came out, because the lever is all over the place. So next question...how do I get the wheel off? I'm guessing I start with removing the horn button. I'm pretty good with my hands, but never took off a steering wheel. Maybe I'll try Youtube!
Getting the steering wheel off is going to do nothing at all....you need to pull the hub...which is the part that the steering wheel is screwed to.
SO...leave your steering well attached to the hub.
YES...YouTube it and go to an OReillys or any auto parts store that has the loan a tool' program and rent the tool to pull the hub.
A harmonic balancer puller tool will also work to pull the hub....just make sure the TWO bolts that thread into the hub are threaded into it pretty well and EVEN so the puller pulls the hub evenly.
DUB
