1957 Wacky Tach question
Wacky action out of my 283/245 HP generator driven tach today. Works fine at idle to about 3000 rpm, then suddenly jumps to 6 o'clock position and makes a bunch of whirling noise for second or two, then back down to normal again. New gears at generator drive, and I pulled and inspected the cable-looks good. Relubed it as described in the posts in my forum search. Still same old stuff. Time to look at the tach? Something which I can inspect/rebuild, or off to an instrument repair shop?
Thnak,
Marc in Indy
Thnak,
Marc in Indy
Received 6,530 Likes
C2 of Year Finalist (track prepared) 2019
The tach mechanism is worn out and needs to be replaced.
Been there, seen that.....
128racecar (02-27-2017)
