[C2] Need help with 1967 Protect-O-Plate decoding
I am in the process of negotiating the purchase of a 1967 Coupe and need a little help on decoding the P-O-P. Here is a picture which I flipped for easy reading. Thanks in advance for your help.
Received 6,943 Likes
2015 C2 of Year Finalist
430/ 983 is green on green
T0307IMH- engine stamp is for a 67 437/390
AU is the rear a 3:36 posi for a BB
C7Premiere (02-28-2017)
Here you go. If I messed it up, someone will correct me!
430 - Trim Code - Green Vinyl
983 - Paint Code - Goodwood Green
13836 - Last 5 of Vin # - 13,836 Corvette built
H - Carburetor Source - Holley
T03071MH - Engine Code
T - Source - Tonawanda
03 - March
07 - 7th
1M - 427-cid 390-hp V-8 with 10.25:1 compression ratio, manual transmission, and four-barrel carburetor
H - Holley Carburetor
AU0307W - Rear Axle Code
AU - 3.36 ratio, Positraction, 4 speed
03 - March
07 - 7th
W - Source - Warren
W - Production Month - May
P7B02 - Transmission Code
P - Source - Muncie
7 - Model Year - 1967
B - Production Month - February
02 - Day - 2nd
03 - March
07 - 7th
03 - March
07 - 7th
W - Source - Warren
P - Source - Muncie
02 - Day - 2nd
T - Tonawanda
03 - March
07 - 7th
03 - March
07 - 7th
W - Warren
P - Source - Muncie
02 - Day - 2nd
T - Tonawanda
03 - March
07 - 7th
03 - March
07 - 7th
W - Warren
P - Source - Muncie
02 - Day - 2nd
430 = Dark Green Vinyl
983 = Goodwood Green
T0307IMH decodes as:
T = Tonawanda engine plant
03 = March
07 = 7th day of the month
IM = Is a 67 427/390, 4 speed and K19 (A.I.R.)
H = Holley carb
AU0307W
AU = 3:36 Posi with 4 speed and 427
0307 = March 7
W = Warren assembly plant
194377S113836
1 = Chevrolet
9 = Corvette
4 = V8 Engine
37 = Coupe body
7 = 1967 model year
S = St. Louis assembly plant
1 = GM control number
13836 = 13,836th 67 Corvette built
I'm a little fuzzy on the P7BO2, but I think it decodes as:
P = Muncie transmission
7 = 1967
B = February
02 = 2nd day of the month
03 = March
H = Holley carb
AU0307W
0307 = March 7
194377S113836
1 = Chevrolet
9 = Corvette
4 = V8 Engine
37 = Coupe body
7 = 1967 model year
7 = 1967
B = February
Wow, I guess I have to learn to type faster, pmvette beat me in by 6 minutes!
At least it looks like our information agrees!
