1966 brake line routing to PB master cylinder?
does anyone have a picture of two of the correct routing of the front and rear brake lines as they come up from frame to the dual master cylinder on a PB car? (mine got a little tweeked over the last year with body on and off, etc.....
btw...should i bench bleed the master before putting it on car, how important? thanks a bunch, Rick
No photo's but runs along bottom of frame and over rear cross member. I always bench bleed master. Much easier. If you decide to rebuild master use seal kit not kit with pistons.One piston is incorrect. It,s been about 10 years kit might have been corrected
