[C2] 15x7 wheels on a stock C2?
Just curious, can you run a 15X7 wheel on a stock C2 without modification, or worrying about cracking fiberglass over a bump? If so, what backspacing front and rear? Lastly, what tire size? Ive noticed theres a drastic shortage in 15 inch performance tires....especially in Corvette sizes.
Thanks,
Greg
Thanks,
Greg
Yes.
Depends on the year ('63-'64 or '65-'67). I run 3-7/8 or 3-3/4" BS (depends on if you consider 1/8" thick "bead" along the inside lip or not).
You can run a 225 and possibly 235 wide without interference.
These are 225/60/15 on 7"-wide Western Wheels.
And you are correct. There are no more high performance tires for these. I got the last set (Z-rated) and you're looking at them.
Received 2,126 Likes
I have American 200-S 15x7 w/3 5/8 BS w/205/70/15. NO issues and my car sits very low due to suspension modifications. Dennis
Im shopping for a '64 right now...is there a difference in tire/wheel clearance between the 63-64 and the 65-67??
It'd sure be nice if one of the retro tire suppliers would make the old Goodyear "Gatorback" tires with the VR rating.
I'm sure they'd have folks lining up to get a set...
Carter
Carter
but it's about an inch shorter than the typical 7.75-15 of the day.
http://www.kelseytire.com/pages/preformancetires4.html
They do however make the Eagle GT P215/65 – R15 which is closer in diameter.
Unfortunately neither of these tires are inexpensive.
http://www.kelseytire.com/pages/preformancetires3.html
Good luck... GUSTO
Received 1,874 Likes
2020 C2 of the Year - Modified Winner
2020 Corvette of the Year (performance mods)
C2 of Year Winner (performance mods) 2019
2017 C2 of Year Finalist
I just got some 225/50ZR-15 Pirelli P Zero "Y" (186 MPH) rated tires recently to use in the TX Mile. I installed them on 7" Rally wheels. They fit fine with my stock front fenders.
JIM
JIM
63Corvette (03-25-2017)
Any pics? Those are 3 inches smaller in diameter...Im just curious how they look in the wheel well as Toyo makes a 225/50/15 in their R888 tires. I had these on my C5 (admittedly in 18s) and absolutely loved them. Id just be concerned about them looking ridiculously small in the wheel well with that drastic of a diameter difference.
These were take-offs for Saleen Mustangs and I would sell the wheels afterwards making the tires almost free.
Just like these:
I run 15x7 rally wheels on my 63 with stock hubcaps and 205/75/15 whitewalls.
https://www.tirerack.com/tires/tires...=P+Zero+System
Good luck... GUSTO
FlyNavy30- I sent you a PM back...I don't have any closeups...but you can get an idea in these pics. Understand I haven't lowered it any yet )I've got coilovers on the front). I had it still up in the air to clear the tall drag race front tires when I went to dragstrip the other day.
JIM
On a drum brake 63/64 if you want to drop it one coil, a classic American mag 7x15 (3-7-8 BS and with a 3-3/4 might have to slightly trim the fender, but not to a noticeable extent!) with a 215/60-15 will fit. The sizes stated fit if you don't lower! This would be your best fit, if you like the race raked look!
FLYNAVY30 (03-15-2017)
anyone running a 215/70/15?....about the same height as the factory 205/75/15 but about half an inch wider...just curious if theres enough room to run that on a 15x7 with 3.75 in backspacing
I have been using both 6.5" and 7" on my 67(unmodified body). I can actually get 8's in the back now as I've installed Global west offset trailing arms. As to tires, I think the 50 series are just too short. I've been running Pirelli V-rated P6000s, Dunlop vintage race tires,etc in 15".
awesome, thanks....love the car!!
