A/C idle solenoid
A/C idle solenoid
I am considering installing a solenoid to increase the idle rpm when the AC compressor kicks in.
Many reviews report about solenoids that lack power to overcome the throttle spring force. See the reviews about this one from Summit https://www.summitracing.com/int/par...-8059/reviews/
Anyone can recommend a good one?
POSSE ZR-1 Driver
I rewired my AC system to keep the solenoid on when I turn the AC on. The idle is a little higher when the compressor cycles, but its better than having to blip the throttle every time the compressor turns on.
alexandervdr (03-18-2017)
I've use this on a couple of time with no problems. If you have extra strong springs on your linkage will NOT overcome. Normal spring seems to work ok.
Click Here for info
George
Click Here for info
George
A/c
I have that solenoid on my 66 with a Holley. It works well but, you must blip the throttle as the A/C compressor cycles on. The solenoid does not have the power to push the throttle back, but it will keep the throttle advanced for the cycle. You can do a search for NOS solenoids, there are vendors selling original units. Jerry
POSSE ZR-1 Driver
St. Jude Donor '07
I tried it on my FI, and the same problem with as with a carburetor; the solenoid will NOT overcome the spring...; you have to set the solenoid before lifting the accelerator.
Bill
Bill
what is the end to end throw of the solenoid pusher arm? To get 200rpm more on the motor, only very little push is needed on the carb lever. Assuming the solenoid arm has more throw than needed, it should be possible to add an intermediate 2 to 1 lever (or any other ratio) that 'gears' the solenoid pusher arm so the force is much higher?
St. Jude Donor '07
possibly a longer accelerator linkage lever to increase the mechanical advantage, but the solenoid mounting point would be a problem (and ugly)
or some combination lever system as you suggest
or a stronger solenoid, if available.. may be the best solution. remember, cruise control systems are able to overcome spring problems... BRAIN FART: with a relay and a servo, that would work...
my personal solution is EFI which maintains idle rpms to whatever I set it at under any circumstances/loads. the BIG problem is space... it's hard enough to cram stuff in the spaces available...
Bill
Just know, you can "over engineer" something until IT becomes the problem and another failure point...
St. Jude Donor '07
Bill
Another one on my list is cruise control, I don't think it's wise to add both systems
factory A/C -- no problem
this Edelbrock unit won't move the idle setting up, but it will hold it after a blip.
Good solution for the factory system with non-cycling compressor design.
Tucks in nicely under that gorgeous dual snorkel!
St. Jude Donor '07
I THINK he is saying that the solenoid is constantly on only when the a/c is switched on and the solenoid does not cycle when the compressor clutch energizes/de-energizes. when the a/c is turned off, idle returns to normal.
this will work, just a 200rpm (or whatever you chose) idle above non-a/c idle.
I could live with that, and not have to do the 'foot tap'...
Bill
Bill
POSSE ZR-1 Driver
Bill
Bill
St. Jude Donor '07
Bill
batman1414 (03-19-2017)
can someone tell me the max throw of the solenoid pusher?
