1965 rear axle codes
Trying to find info on my rear axle. It looks like it says 2AV7264 and I can'y find that type of number combo on any ID site.
Received 6,929 Likes
2015 C2 of Year Finalist
There is no AV code. Could it be a AU? If so it's a 3:36 posi from a BB
I agree with Nowhere Man it could be an AU.
The format is Prefix (application code), month, day and year.
In your case 2 which is not typical, AU(possibly) 7 (July) 26 ( 26th of the month) 4 (possibly 1964 or 74).
This raises several questions with the information as stated.
The July 26 of '64 could be a fit if your car is a very early build '65.
But then AU would not as big blocks were not available until February of '65. I doubt they were building production big block difs that early.
Then there is that first character 2. This is not not typical for a midyear Corvette. In the later years the differential stamp format changed and had more characters. I am not really familiar with them. But I I do know that by 1970 the application code had 3 alpha characters. So this does not fit the 1974 scenario.
What is the VIN of your car?
Can you post a nice clear picture of the stamp?
Some rears had a number prefix, to indicate which shift the rear was assembled during. In this case the "2" would be the second shift. Additionally, from my experience, Warner usually stamped the year using two digits not one, making the date July 2nd, not July 26th.
"AV" was the code for a big block 3:08 Posi rear, in 68 and part of 69. Could the date code be 7269, instead of 7264????
This is much more plausible, since AV is a rear end code used in 68-69, and 68-69 rears typically had shift stamped in them, while 63-67 usually didn't.
I agree with some of what you're saying here.
I think your right on the AV code. I had a quick look in source material but missed it. Probably because I was looking at 1970. My bad again.
As I said I knew the format changed in later years. I just couldn't recall how it went. I was thinking I was mistaken about the shift when I saw the 3 character application code in '70 and later. Seemed like a lot of stuff in one stamp. Again, my bad.
I know a little about '67 and earlier. But that little bit drops way off for '68 and later.
I believe you've nailed it. Good one
I just looked at a wilcox list of rear axles and they do show a 3.08:1 for a 4 speed 327 posi for 1965 but the code is AL. My guess is that is what is in this car.
The trans and engine are numbers matching just not sure about that rear diff. Any comments are appreciated.
It is indeed 2AV7 2 64. Just as the OP said.
Yes very hard to see but it looks like CONI the last digit might be a 1 or large case i They are all raised letters or numbers and there are to little raised casting marks before and after like *CONI*
Where your picture has a number that looks like E185 mine has no numbers at all in that location
Your right. Good catch on the year date format. My bad.
2AV7 2 64 spaced like I typed it.
"AV" does not match a 3:08 rear for your car, because AV was not used in 1965. It was only used as a 3:08 Posi with 68 and 69 427's. In 65 the codes for a 3:08 rear were; "AR" for the open 3:08, "AL" for 3:08 Posi with a 327, and "AT" for the 3:08 Posi with a 396.
Additionally, your VIN indicates that your car was built in Feb. 65, and that rear is dated July, 64. This is almost 7 months before the car was built, and outside of what's considered a normal time line for parts used in production. Even if the "V" is a miss stamp, the assembly date is abnormal too.
It would be helpful if you could find the casting date for the rear, and maybe the one on the rear end cover too.
I'm sorry, but I don't think any of the codes or dates line up.
BB rear ends have heavy duty side yolks or ones that get a cap that's bolted to the yolks rather then the strap like on SB rears. If the rears been apart it can be changed. But the bolted side yolks are sought after becouse are stronger. So not sure why one would change that
Yellow65FI (07-28-2020)
I know this is an old post, but if anyone is using it for research:
I think it is a 1969 production year AV coded rearend, originally lightly stamped “68”. The someone has lightly ball peen hammered over top of the 8 and stamped a 4 over it to make it work better in a ‘65 car. They may have tried to restamp the 6 deeper as well as I don’t think the ghosted 6 in the background is the same font, and you don’t see ghost stamps or bounces on rearends very often.
