[C2] 327 vibration at various rpm
I have a 66 coupe base model (300 hp/327 automatic ) the engine was rebuilt some time ago but sat most of the time. I have had it for a couple of years and drive it religiously every 2 weeks. I get a vibration at about 1500 rpm, 2500 rpm 3500 rpm. (Static,in the garage ) l am thinking it's the harminic balancer. Any help would be greatly appreciated. MARK
Received 1,843 Likes
My experience with engine vibrations tells me if the cause of the vibration is internal to the engine, it will come in hardest at one particular rpm. It's been a long time since I diagnosed an internal vibration so take this for what I'm charging for it.
I'd make sure the exhaust isn't grounding to the frame somewhere.
Remove the fan belt and see if the vibration goes away.
Put the car in gear, with the clutch pedal in and rev the engine to the affected rpms. Did the vibration go away?
Check the easy stuff first.
I've never had a harmonic balancer fail so I can't comment on that.
A harmonic damper doesn't really "balance" an engine, unless it is 400 or other motor that is externally balanced.
The damper is tuned to a specific frequency that your crank shaft will set up self destructive vibrations at that you probably can't even feel, and IIRC, this is something that only happens at one RPM range in the motor.
I would look for something else first as Mike M suggested.
Doug
Doug
Received 2,127 Likes
Since its sitting still and and running, you say, "I get a vibration at..." do you hear and feel the vibration? Have you checked the alternator mount. If it has P/S, check thr pump mount. If you put the car in gear, does that change things? Dennis
Doug
Doug
I broke a crank years ago due to having the wrong harmonic balancer on my SHP 327. I never felt the first vibration. Same thing with four of my buddies running the same engine, same rear gear, and same driving habits.
