1958 Running Hot
1958 Running Hot
My 1958 Corvette constantly runs hot. I have replaced the thermostat and the radiator has been rodded out. Has anyone experienced this problem? Does anyone have any suggestions on how to fix it?
2023 Restomod of the Year Finalist
How hot, verified by what? Low speed or high or both? Have you verified the temp with a laser thermometer? What's your fan & shroud setup? Need a lot more info...
There are a lot of things that can cause overheating.
Dennis
My problem is my gauge.
Have you actually checked the temps with an infrared scan tool?
Record the upper and lower hose temperatures. Then check the temperatures at about 3 different places on the radiator.
Richard Newton
How Hot is Hot?
Richard Newton
How Hot is Hot?
lower hose should have spring to prevent collapse as water pump sucks. as mentioned, check actual temp, sending units are all over the place. other less likely causes; water pump worn out, timing, obstruction in motor, obstruction is air flow.
Verified by the temperature gauge. It runs hot at idle. No I have not verified with a laser thermometer. Fan & Shroud are stock, as well as everything on the car.
Check your lower hose for collapse. I did everything else on my'57 before I looked at this, and sure enough a hose that looked good was collapsing at temperature. Gates does not make them with the spring inside to give more support. I went with a universal with a molded in spring and no more overheating, Just my experience though,
Dennis
Dennis
2018 C1 of Year Finalist
Not sure on a 58 but how is your fan setup? Is it aligned right with the fan shroud.
Mine will run about 180 to 210 which to me seems fine. Last Saturday night, it was nice and cool. My corvette never went above 180. I am running a clutch fan.
Also, how is the spacing around the fan? You might just need to make sure your fan shroud and fan setup is good to go.
Otherwise, if you are worried about the radiator then replace it with a dewitts radiator and never look back for awhile. Though, from the sounds of it the radiator is working fine. Thermostat is working.
Get an IR gun and check it at idle.
Richard Newton
How Hot is Hot?
Richard Newton
How Hot is Hot?
