Cylinder Heads Installation Question
Greetings. So I just had a bunch of work done on my '65 at a local shop. Most of the work was on the suspension, tires, and wheels, but I did have these new cylinder heads installed as well. Are the gaps/holes above the exhaust headers normal? I have to take her back up there for some timing and/or valve adjustments to get rid of some backfires, but I wanted to reach out here to see if these new heads were installed properly. Do I need new headers, gaskets, or something else, or are these spaces OK? Thanks.
Received 6,943 Likes
2015 C2 of Year Finalist
What kind of heads did they put on. It looks like the exhaust ports don't line up with your headers
The heads they replaced were double hump fuelie heads (3782461), which these should be a direct replacement for.
Take a look at the pictures of the heads on the company's website. Those gaps aren't the exhaust ports, but i don't know if they should even be exposed?
If these are the heads they installed, and unless you are seeing or hearing any exhaust leaks, I think your heads are fine. I've never seen these (red boxes) cast in a cylinder head, but again if there are no leaks, you should be good.
Good luck... GUSTO
Good luck... GUSTO
Received 3,043 Likes
St. Jude Donor '05
next time around consider spark plug boots with 90 deg angle if those burn up
Also, I have more information. Those 'gaps' are actually holes for mounting spark plug wires. My headers flanges are too big to use them (partially covering), but this is a non-issue. Thanks to everyone for their responses!
Received 1,919 Likes
BluePrint Engines H2008K
Once you get your problems sorted out let us know what you think about these heads. At $895 a pair assembled,
this is something that I would be very interested in.
Ray
Ray
Received 2,127 Likes
Your distributor looks like it not phased correctly. The vacuum can should be in the 4-5 o'clock position. It may be tied to your backfireing problem. The intake manifold is designed for mid to upper rpm engine operation range coupled with low gears such as 3:70 or higher as opposed to a dual plane intake that is good for 3:55 and lower. Talk to the shop. Check the clearance between the upper rad hose and the alternator belt. A cut hose will sideline you real quick. Dennis
St. Jude Donor '05
Good price but may be concerned about where the valves and springs come from.
Maybe Blueprint can pipe in they are on here a lot
St. Jude Donor '05
fwiw Trick Flow makes an aluminum head that looks identcal to a camel hump iron just works way better
Received 1,857 Likes
The following 5 users liked this post by JohnZ:
Easy Rhino (03-27-2017),
GUSTO14 (03-27-2017),
jimh_1962 (03-27-2017),
mikelj (03-27-2017),
new vette 62 (03-27-2017)
The following 6 users liked this post by Frankie the Fink:
new vette 62 (03-27-2017),
OldKarz (03-29-2017),
Rich Yanulis (03-28-2017),
and 1 others liked this post.
check that vacuum advance, backfire will pop it pretty easy. also distributor not indexed correct as previously mentioned. These heads take 3/4 reach plugs, surely they installed correct new plugs?
