Cam bearing for a '67 327 with a comp cams XE268?
7th Gear
Hello, I'm putting a comp cams XE268 in my 327 but the cam bearing is wrong for this cam. Any ideas on which bearing I need?
Thanks,
Heavy Z
Thanks,
Heavy Z
Re: Cam bearing for a '67 327 with a comp cams XE268? (Heavy Z)
Never heard of that problem.
I was under the impression that all small block cam bearings are the same.
I doubt if you have aftermarket "roller" bearings (not roller cam).
Like Grumpy said, your problem isn't with the cam bearings as they are all standard and a replacement cam will have the same bearing journal size as an original cam. If you're having a problem getting the cam to slide in, you may not be pushing it in exactly straight. Anything other than a perfectly straight shot and a journal with hit the edge of a bearing and stop. Also be careful of the distributor drive gear as it can do serious damage to bearings if it scrapes them while passing through.
Received 2,127 Likes
Re: Cam bearing for a '67 327 with a comp cams XE268? (Vetterodder)
If you don't get it in, buy a special device at Jeg's or one of the on line shops. It's just for installing cams, or you can by some all-thread at a hardware stor and make you own. Hope this helps. :cheers:
Received 1,857 Likes
Re: Cam bearing for a '67 327 with a comp cams XE268? (Bluestripe67)
I assume you have removed the fuel pump and pushrod....
