Who Can Make The Grade..... Get Your Bolt Tech Hat On....
Old 05-03-2003, 08:01 PM
Viet Nam Vett
Support Corvetteforum!
Viet Nam Vett's Avatar
2015 C2 of Year
St. Jude Donor '04-'05-'06-'07-'08-'09-'10, '14-'15
Default Who Can Make The Grade..... Get Your Bolt Tech Hat On....
Ok .........Who Knows this one..
What is the Factory Bolt Grade Rating on the 4 Bolts That Hold the Rear Spring on ...(1965 C2) to the Diff??? Grade 5 Or Garde 8? My spring is an after market and is 2..5/8 inches thick. Got me some Grade 8....4 inch bolts (2) only. And 4 grade 5.
Now heres the RUB... :banghead: ...the 2.........4inch grade 8's look like they will only grabe about 1/2 inch of thread in the diff holes.. I could only locate tonight grade 5...4-1/2 incher's. I'll try tomorrow to get grade 8, but can I use grade 5 if I can't find grade 8?
It looks like the 3..1/2 incher's won't grab enough threads. :banghead:
How much compression will the rubber between the spring move in??
It figures that this is the last thing I have to do before I drop the car to the ground.. Now a bolt is holding me up. :banghead: :banghead: :banghead:
Old 05-03-2003, 08:47 PM
gary6696
gary6696's Avatar
St. Jude Contributor '03 & '04
Default Re: Who Can Make The Grade..... Get Your Bolt Tech Hat On.... (Viet Nam Vett)
The GM parts book doesn't say, but Paragon's replacements are grade 8, and grade 8's are what are on mine.
I would not be afraid to use grade 5's myself.
Old 05-03-2003, 08:50 PM
achapman
achapman's Avatar
Mine are Grade 8's also.... :smash:
Old 05-03-2003, 09:00 PM
Hitch
Hitch's Avatar
Default Re: Who Can Make The Grade..... Get Your Bolt Tech Hat On.... (achapman)
VNV You mean Bubba's Warehouse (Lowe's/HomeDepot) didn't have any long enough. I usually find they have a great selection of Grade 8 Bolts etc to bad they are Zinc plated. Dave...
Old 05-03-2003, 09:07 PM
Viet Nam Vett
2015 C2 of Year
Default Re: Who Can Make The Grade..... Get Your Bolt Tech Hat On.... (youwish2bme)
Heh Dave.... Home Depot has the right lenth but grade 5 only... Haven't checked Lowes yet..
Old 05-04-2003, 03:03 AM
SWCDuke
SWCDuke's Avatar
Received 1,974 Likes on 1,188 Posts
Mine are original and only have a vendor mark on them - no radial lines so they may be only grade 3. The torque spec is 55-75 and the only load on them is the clamping load to keep the spring in place - no dynamic loading since the spring reaction force where it mounts to the diff is always up.
Grade 5 should be perfectly adequate.
Duke
Old 05-04-2003, 09:31 AM
Viet Nam Vett
2015 C2 of Year
Default Re: Who Can Make The Grade..... Get Your Bolt Tech Hat On.... (SWCDuke)
Thanks Duke.... WIll pick up some G 5's today and finish the install. Man...an I going to be glad when this job is done....I hate rolling around on the floor!!!
:cheers:
Old 05-04-2003, 09:33 AM
achapman
achapman's Avatar
:cheers:
That's not what she said.... :lol: :lol: :lol:
Old 05-04-2003, 11:27 AM
gary6696
gary6696's Avatar
"Man...am I going to be glad when this job is done."
Yeah, but what are the rest of us going to do for entertainment?
Jeez, Mark, you got more problems than a woman with PMS who has lost her credit cards! :lolg:
Old 05-04-2003, 11:41 AM
Kid_Again
Kid_Again's Avatar
...yeah, you need to find a partner to roll around in all that dirt on the floor..."why don't we do it in the road...." :D
Old 05-04-2003, 01:57 PM
Viet Nam Vett
2015 C2 of Year
Default Re: Who Can Make The Grade..... Get Your Bolt Tech Hat On.... (gary6696)
Well I just needed a break...Got the spring in..It was a 50/50 mix of bolt grades 2 Grade 8 to the rear...2 grade 5 facincig the front. Now I'm ready to mount the KO Hubs and put the tires on and drop the car and tighten the spring bolts to the final torque.
I should of had my lady fried come over and do this job... She's always on the PAD...and uses my credit cards!!!! But the last time she helped me was when I tried to lub my speedo cable and she ended up with a 2 lb blob of chassie grease all over her face and chest after my ingenious plastic hose tube attachment to the grease gun exploded!!!.... :lol:
[Modified by Viet Nam Vett, 1:58 PM 5/4/2003]
To Who Can Make The Grade..... Get Your Bolt Tech Hat On....
Quick Reply: Who Can Make The Grade..... Get Your Bolt Tech Hat On....
