Turn signal switch replacement question
Re: Turn signal switch replacement question (Cliff63)
Actually it was a PITA.
To make matters worse....
My right rear brake light and right rear blinker still dont work.....
I thought for sure it was in the switch.
At least my steering wheel is tightened up with the new bearing
that comes with the switch.
But like I said. It was a Huge PITA and didnt do what I thought it would do.
Re: Turn signal switch replacement question (396 RAT)
to point out what you surely already know, if the brake light and the signal are both not functioning at a corner of you car, it probably ain't the signal switch but something back at that corner, bulb/socket/ground issues . . . .
Re: Turn signal switch replacement question (ctjackster)
Agree, but after trouble shooting everything I could think of back there
many thought it would be in the switch.........
(Seemed like a good idea at the time) :lol:
(as both blinker and brake lights run through it)
The running lights work back there, but no right rear blinker or brake light.....
Will have to just get back on it...........
Re: Turn signal switch replacement question (sams'66)
I really do have a question. My turn signal dosen't cancel when making a right and won't hold when I make a left ( I hold it down while when johnny law is behind me)
I removed the wheel and all looks fine. The plastic is a little yellow but I don't see anything jumping out saying it needs to be replaced. Any testing ideas? TIA
