Backspace of '67 15X6 Rally Wheel?
Old 02-10-2004, 10:23 AM
jkmhb
jkmhb's Avatar
Default Backspace of '67 15X6 Rally Wheel?
I got rid of my aftermarket dual bolt pattern rally wheels (they would actually flex in the center when you bolted them on - a very strange design). They were 15X6 with a 4" backspace. The rears would barely (within 1/16") clear the emergency brake clip on the trailing arm. I plan to get the Pirelli P4000 215-70X15 tires.
What was the backspace of the factory 15X6 rally? Anyone have feedback on the Wheel Vintiques series 30 rally?
THX.
Old 02-10-2004, 11:13 AM
SWCDuke
SWCDuke's Avatar
Received 1,973 Likes on 1,188 Posts
Default Re: Backspace of '67 15X6 Rally Wheel? (jkmhb)
Offset of the OE 6" Rally Wheels is +0.060". [edited to correct value]
Duke
[Modified by SWCDuke, 9:48 PM 2/10/2004]
Old 02-10-2004, 11:16 AM
waynec
waynec's Avatar
From notes I've made from past posts on various forums, the backspace for the 67 Corvette 6x15 "DC" rally is 3.56 inches. That should give you a bit more clearance.
The 6x15 "FW" rally (Camaro?) is 3.8 inches.
Old 02-10-2004, 12:22 PM
grumpy55
grumpy55's Avatar
Default Re: Backspace of '67 15X6 Rally Wheel? (waynec)
SWCDuke,
Should that be 0.06" (not 0.60") ?
Old 02-10-2004, 12:58 PM
JohnZ
Support Corvetteforum!
JohnZ's Avatar
Received 1,856 Likes on 1,099 Posts
Default Re: Backspace of '67 15X6 Rally Wheel? (grumpy55)
It's +.060" (sixty thousandths). :thumbs:
Old 02-10-2004, 01:24 PM
66427-450's Avatar
........The 6x15 "FW" rally (Camaro?) is 3.8 inches.
my notes say that FW is a "7" inch rally, with a +.3 offest (camaro/monte). and I agree +.06 for the '67 6" wheel.
Old 02-10-2004, 01:34 PM
jkmhb
jkmhb's Avatar
So - what is the relationship between backspace and offset? Should you be able to calculate one, given the other?
Old 02-10-2004, 01:45 PM
Paul L
Paul L's Avatar
*Deleted*-A misleading link to offset/backspacing was provided by me. My apologies to Members.
[Modified by paul67, 2:40 PM 2/10/2004]
Old 02-10-2004, 02:14 PM
JohnZ
JohnZ's Avatar
Default Re: Backspace of '67 15X6 Rally Wheel? (paul67)
Very nice explanation and graphics, but they're wrong - they have it backwards. There is not, and never has been, any disagreement in the OEM community about the definition of positive-vs.-negative offset; note their words at the end - "that's the way we do it".
The OEM definition of offset hasn't changed in over 80 years. If the wheel bolt-up face is outboard of the centerline of the rim, that's positive offset; if the bolt-up face is inboard of the centerline of the rim, that's negative offset.
A much better reference for wheels is at:
http://www.rsracing.com/tech-wheel.html
:cheers:
Old 02-10-2004, 02:38 PM
Paul L
Paul L's Avatar
Default Re: Backspace of '67 15X6 Rally Wheel? (JohnZ)
I will remove the bad link/reference.
To Backspace of '67 15X6 Rally Wheel?
Quick Reply: Backspace of '67 15X6 Rally Wheel?
