How to remove windshield wiper arms on a '67
Hello,
I'm trying to remove the windshield wiper arms on my '67 coupe. Any suggestions on how to do this?
Thanks!
Thanks!
Re: How to remove windshield wiper arms on a '67 (USA1LT1)
NAPA sells a tool for it, they had to order it for me, but it was only $14.99.
It makes the job much easier.
Re: How to remove windshield wiper arms on a '67 (Nicky71)
Get "the tool". Looks like a pair of pliers, except when you squeeze the handle, the other ends "opens". You can pop the arms off easily. Resist the temptation to vice grip them and pull them off. :)
If NAPA doesn't have one, try Pep Boys, AutoZone, Salvo, etc. Look in the relatively cheap KD tool section. Chuck
2 screwdrivers under the either side will pop them right off. Just lie a blanket across your hood when they fly off.
I bought one of the removal tools and bent it trying to remove mine and was afraid I'd bend my wiper arms. It was the tool thats slightly bent with a hook that goes under the end of the arm and you squeeze the tool and the wiper arm together to pop it off, but didn't work.
Re: How to remove windshield wiper arms on a '67 (Jeff Garner)
I bought one of those same tools a few years ago and it works great. I can have the arms off in seconds. There is a little technique involved, apparently. :auto:
Received 1,856 Likes
Re: How to remove windshield wiper arms on a '67 (62fuelie)
Here's the tool - makes wiper arm removal and installation a piece of cake, without scratching paint or flying parts; this one is made by "K-D Tools" - any good auto parts store carries them.
:steering:
:steering:
Re: How to remove windshield wiper arms on a '67 (JohnZ)
That's exactly the tool I had. I'm glad it works for you.
I SAW A PICTURE OF THE TOOL IN THE LAST POST--- NOT TO EMBARRASS MYSELF BUT HOW DO YOU USE IT?
:confused:
:confused:
:steering:
:steering:
Re: How to remove windshield wiper arms on a '67 (VETTE1966)
:confused:
:confused:
Geez guys, all you got to do is pull up and push down at the same time and they pop right off. :confused:
Re: How to remove windshield wiper arms on a '67 (Brutal64)
I spent the bucks for the tool right after I paid #300.00 for a set of 64 OEM "bright" arms and blades, the blades have the bumps on them. At that price I want to scratch nothing. :beatdeadhorse:
Re: How to remove windshield wiper arms on a '67 (Tevroc98)
Anyone have a KD part number? Thanks
LIC has it for $6. #16 in Sect 55
http://www.licorvette.com/pdfcatalogfiles/cat22/55.pdf
Haven't tried mine yet.
DZ
[Modified by DZVette, 4:50 PM 4/8/2004]
DZ
Re: How to remove windshield wiper arms on a '67 (DZVette)
Worked as advertised:
It is a "piece of cake" as someone said above.
DZ
[Modified by DZVette, 7:24 PM 4/8/2004]
[Modified by DZVette, 7:27 PM 4/8/2004]
DZ
Replacing wiper arm with cap
So I was able to get the arm off. But anyone have any suggestions where to go from here the cap is pretty shallow. Do I leave the end alone and attempt to unthread the inner part closest to the chrome?
Tim,
What is it you are trying to do? The threaded area should have a bezel that screws on it and secures the wiper transmission to the body. The wiper arm that you have pictured isn't going to fit correctly. It's too shallow. On the inside underneath of a correct arm, there is a spring-loaded tab the locks the arm to the splined shaft. Don't think your arm is anywhere deep enough for that to hook.
