circuit breaker location ?? 1966 coupe
can anyone send me a picture or a diagram of the location of the circuit breaker for my 1966 coupe. my repair manual says it should be located at the top of my fuse box. there's nothing there. could it be missing? i just bought the car & this is my first vette. thanks for any help. e-mail pics to tpuska3@shaw.ca
I've never seen a circuit breaker on a midyear. There are breakers/relays for power windows and other accessories. What are you looking for? What are you having trouble with? Chuck
Received 1,857 Likes
There's a self-resetting 30-amp circuit breaker on all midyears, in the red power feed wire to the headlight up-down switch; it's located on the inside of the driver's side hinge pillar, above the top of the kickpad. If you have power windows, there will be two of them, in the same location.
Yep, you've got headlight and power window (if you have them) breakers in the car, but as JohnZ says, they're behind the kick panel on the drivers side, not tied into the fuse box, and not to the best of my recollection mounted near, on, or above the fuse box. Chuck
Had my 63 AIM out, as I'm working on the car. If you look in Section 12, Sheet B 9.00 in the 63 AIM, likely a different page in your 66 AIM, "Instrument Panel Harness, Switches, And Cigarette Lighter", you'll see the inline headlight breaker mounted in the jamb behind the kick panel. If you look in the A31 "Power Window" Section, you'll also see a pic of the breaker for the power windows, IF you have that option. Sorry if I confused you with my first answer, as there is no "general" breaker for the car, and none in/on the fuse panel. Chuck
