octane boost
octane boost
Do octane boost really work I have an L79 freshly tuned to specs but get a ping at lower rpms. going to try a boost in octane to see if this helps.Anybody ever use a boost???? If this does not work then will play with timing but would rather not.
Do not buy octane boosters.
Your car should run fine on pump gas. If you are getting some knock, reduce your timing a degree or two.
If you want octane, find some racing fuel and mix it with super unleaded to get the octane you need.
If you need more information, search the forum for 'octane booster' and 'racing fuel'. We have discussed this many times over the years.
I will follow up with the threads on the forum, but my L79 LOVES booster (104). It does run on 93 octane, but not very well. A bottle of 104 with each tank and the difference is amazing...gary.
Received 1,974 Likes
L-79s have 30 degrees of centrifugal, so even though the initial is probably recommended at 10, you only need 6 to 8 to get the desired 36-38 total WOT advance.
Retarding you timing as little as 2 degrees could do the trick. Also, someone may have quickened the centrifugal curve, so check it against spec and slow it down if necessary.
"Octane boosters" are a waste. If you really need more octane, blend in some 100LL avgas ofrhigh octane race gas. As little as a ten percent blend could do the trick.
Duke
Duke
Duke
Duke
I don't agree that all octane boosters are a waste. Some do raise the octane of gas, especially those with analine oil (not sure of spelling). It's not an over the counter item, but it is used in some brands of octane booster (in some it is nothing but analine oil). It is proved to raise the the octane by 2 to 4 points (not .2 or .4)
Received 1,857 Likes
When the "snake-oil" octane boost peddlers advertise "points increase", it's in tenths of an octane point, not full points. The stuff is mostly alcohol and "petroleum distillates", which is not friendly to standard gaskets, and will eat the protective plating off the inside of your float bowls (then the alcohol content attracts moisture - it's extremely hygroscopic). Unprotected zinc and water isn't a good thing.
Received 1,843 Likes
Long paper on the search for anti-knock formula
http://www.runet.edu/~wkovarik/papers/kettering2.html
Aniline oil is mentioned several times starting with "early research".
a difference, shade tree i know but had to
Once again, thank you guys (especially you senior members who provide such a wealth of knowledge)...this is great info., it's nice to save $$ and treat your mid-year better at the same time!!!
I have L-79 that likes good gas
I am playing with the timing on mine to check and see if I can get Amoco 93 to work and still have a decent responding engine or not.. I have played with timing and weights and spring in the distributor and etc. right now I think I'm at around 12 degree's at 800 . What I have noticed is the car gets really lazy if I drop down into the 8 or 10 initial advance range, but my ping does go away. I have also noticed that my car pings more in warm weather. I put a full tank of 110 octane in the tank and I'll guarantee it didn't ping then but,, honestly it was leaded racing fuel and it left a white powdery substance all over my rear bumpers. Duke says 30 degree's of centrifigal and I believe him. but last time I checked all I could get was 20. I probably didn't rev High enough. I don't think I'm helping much but,, my engine may not exactly be stock,, I really don't know.
With the timing (i.e., initial and centrifugal) are set to spec my '65 L76 is stock and runs fine on 94 octane with no detonation . Your L79 should not need any octane booster if everything is set up correctly.
Same problem here in Arizona with 91 octane - I mix 3-4 gallons of race fuel (available at a local 76 station - $4.50 gallon!) per tank with my L79 and it works great - each area of the country is different - of course sea level vs high alitude is a different story.......
