Fs 283 Block Casting 3789935
FS 283 Block Casting 3789935
283 block casting number 3789935. just out of the machine shop, honed and bored .30 over, block decked (no Ser#). line honed, cleaned, new freeze plugs, cam bearings. This block came with a 1961 C1 I purchased, (not the 0riginal engine) but do not plan to use the engine and I really don't know the history it. 500.00 plus shipping.
Casting Date
The casting date is J161, which I believe is oct 1 1961, I think the three number code means this is a townada casting.....which from what i read was not put into corvettes. Hope that helps.
Actually the date code J161 means Octobe 16, 1961 and the single digit for the year notates Saginaw manufacture. Tonawanda cast small blocks normally use the last 2 digits for the year and the castings were not used in Corvettes except for a few in 1965.This info comes from the NCRS spec guide.
Received 1,857 Likes
If it has this square-head 1/8" NPT plug at the front, it's a Flint block; if it doesn't, it's a Tonawanda block.
Yes, but not a Corvette Block
While true that the it is a Flint block, it is not true that it is from a Corvette.
"935" blocks were used interchangably with "519" blocks during the last few months of 1961 model year production (from approx serial #9500 on) as GM ran out of 519 blocks before they ran out of cars to put them in. Therefore the only possible casting dates for a 935 block in a 1961 Corvette would be from F and early G (June, July 1961).
But yours is dated October 1961 which would mean that it would be for a 1962 model. However 1962 Corvettes were fitted with the new 327 cu in engine. Thus your engine is from a 1962 passenger car. If the pad stamp was still intact the letter codes could be used to pin it down exactly. There is nothing wrong with your engine, it is ostensibly the same as used in Corvettes, just that the dates won't work.
Hope this helps to clear things up!
Mike
Mike
Mike
Mike
http://www.ebay.com/itm/360478506784...r#ht_894wt_699
Location: About 1100 miles from where I call home. Blue lives matter.
Received 5,323 Likes
Dont dredge up 7 year old threads:
If an existing thread has not received a reply for a period of 45 days or more, members should create a new thread which is identical or similar in nature, rather than to post to the existing one.
Similar or identical threads created under 45 days will be considered a dupe, and will be locked accordingly.
This rule will not apply to technical discussions or to posts in threads where such posts have been made to update the threads with information deemed by moderators to be of benefit to Forum members.
________________________________________
http://forums.corvetteforum.com/foru...s-or-more.html
If you have a question for a member, send him a PM...
