C1 & C2 Parts C1 & C2 Corvette Performance Parts, Rare NOS and NLA Chevy Parts, Wheels & Tires, Exterior Enhancements, Aftermarket
65 L78 396 425 Hp Original Holley 3124 Carb
Old 04-27-2006, 01:54 AM
rjjudge
Support Corvetteforum!
rjjudge's Avatar
Default 65 L78 396 425 Hp Original Holley 3124 Carb
http://motors.search.ebay.com/_W0QQsassZrjjudge
65 CORVETTE HOLLEY 3124 CARBURETOR
ORIGINAL L78 396 425 HORSEPOWER 780 CFM HOLLEY 4 BBL
GM factory installed ORIGINAL off an original 1965 396 425 Horsepower Vette. This carb was recently treated to a concourse restoration and set up on a wet flow bench
with 0 miles on it and is MINT! The numbers on the carb are as
follows: GM factory part# 3868826 List number 3124 Date code 3rd week of
March, 1965! It still retains the factory installed peanut or
acorn float bowls. It also retains the originally
installed correct 5583 and 4519 primary and secondary metering blocks! Item number: 4634281441
Mention you saw it on this fine web site and I will make a contribution to the Corvette Forum coffers. Thank you, Rob.
Old 04-29-2006, 04:42 AM
rjjudge
rjjudge's Avatar
Hi Kevin, Hope all is well. It is NOT painted gold. It is the correct gold cad plating done by www.customrebuiltcarbs.com 732-356-4333 ask for Phil, he is one of the best. All the best, Rob.
Old 05-03-2006, 05:28 PM
TESTADURO
TESTADURO's Avatar
How Much?
Old 05-09-2015, 02:40 PM
reichs67
2nd Gear
reichs67's Avatar
Need 5583. Metering block
To 65 L78 396 425 Hp Original Holley 3124 Carb
Quick Reply: 65 L78 396 425 Hp Original Holley 3124 Carb
