Corvette Parts!
Corvette Parts!
1. 1958-61 Corvette Intake Manifold #3746829 with oil splash shield. The intake bolt holes have great threads! Just sand blast and paint!
$100 plus shipping-$25
2. 1957 Corvette engine block #3731548 casting # C267 and F429L on pad. The block is standard bore and comes with pistons, rods, and crankshaft. The auction also includes the following: Matching 1957 Corvette cylinder heads # 3731539 with exact casting numbers K16, 1957 Carter WCFB 4 Jet Carburetor (No tag), oil pan, and timing cover. $1000
I will provide crate, shrink wrap, and will deliver to loading dock!
Buyer responsible for shipping arrangements. I have contact information for Roadway Incorporated (770) 496-5200 for shipping quotes and my zipcode is 30060.
3. 1957 Corvette 3 Speed Saginaw Transmission Main Case #3845122 with all components. The sidecover is #3845157 with casting #J556 and can also be used in Corvette restoration. The tail shaft cover is #3707795 and was not used in Corvette applications. (No bolt holes to accept floor shifter). The casting date is K156 and the main case stamping is M1204. The bellhousing is #3733373 (Not Corvette) but is included in the sale. $250 plus shipping-$100
4. 1964 Corvette Rocker Moldings OEM GM Nice Drivers! One molding has a small dent on the the bottom under the car where a bolt attaches to moldings. $150 plus shipping $20
5. 1967 Corvette Sill Plates, Original GM NCRS that removed from 1967 Corvettes during restoration. Great for driver cars since the sill plates have scratches, dings and chips. $30 plus shipping $15
6. 1960's Service manuals 1964 Corvette, Chiltons 53-62 repair and tune up guide (great shape), and 1962 Corvette service guide. These manuals have been in the shop for many years and are original GM prints. The 1964 Corvette service manual is missing a back cover page and has stains and ink marks on cover. The Chiltons 53-62 book is in great shape! The 1962 Corvette service guide has stains and a ripped cover. $60 plus shipping-$10
7. NOS 1967 Corvette Horn Button #3899365 Midyear NCRS C2 still in factory gm box. Not Reproduction! Perfect Condition! $200 plus shipping-$10
8. 1961-1967 Corvette NOS Tail light lense set 62 63 64 65 66 C2 new in the box. This set is perfect for your NCRS Corvette Restoration. $75 plus shipping-$10
9. Original 1965-67 Midyear Corvette drivers side door and two headlight buckets. The door has been repaired near the door handle and is split in door jam area. The door has no glass, door panel, handles, ect. Easily repaired. The headlight buckets are as follows: The sanded bucket HAS BEEN SOLD LOCALLY and not included in sale. The marlboro maroon bucket has dents and a broken tab. Also included is two sets of rear hatch latches and one set of rear hatch body latches.
$350 plus shipping-$75
10. 63-68 Corvette Steering Shock Absorber brackets and three bolts for 250, 300 HP except PS. The shock absorber and brackets were removed from a 1966 Corvette during restoration. The brackets need a good sand blasting and a coat of paint. The shock absorber is aftermarket AC Delco and has a dent in the piston. $50 plus shipping-$12
11. 1967-1969 427 Corvette Headers and side pipes C2 and C3 that came off a BP Corvette racecar. These pipes have been raced and have minor dents and dings. The baffles are included and are installed in the side tubes. See photos where headers have bottomed out at the racetrack and loading onto trailer. $500 plus shipping-$100
12. 1967 Corvette Block- 3892657 Casting date D 10 7 and is .30 over. The cylinders have rust and will need to be taken to .60 over to clean up. The block has been cleaned and still contains windage tray bolts in main caps. The engine pad has NEVER been decked and contains no stampings. $350
13. 1966 Corvette Big Block 427 390HP oval port heads casting #3872702 and date codes of L15 and K265. The cylinder heads need rebuilt. $350 plus shipping-$85
14. 1966 327 Corvette Block .40 over with main caps only. Freshly cleaned with new cam bearings and freeze plugs. Casting date K35 November 3, 1965. The engine pad will need decked. $350
Buyer to arrange shipping. I will assist with crate and shrink wrap and will drop off at loading dock. I do have contact information for Roadway Inc. (770) 496-5200 for shipping quote and my zip code is 30060.
PM for photos! Thanks for looking!
PM sent.
