C1 & C2 Parts C1 & C2 Corvette Performance Parts, Rare NOS and NLA Chevy Parts, Wheels & Tires, Exterior Enhancements, Aftermarket
Lunati Retro Fit roller camshaft
Old 01-15-2009, 09:34 PM
Corbrastang
Corbrastang's Avatar
Default Lunati Retro Fit roller camshaft
$230.00
1st- I guarantee your satisfaction! If for any reason you are not satisfied with this camshaft you can return it for a full refund. This camshaft only has 20 miles on it. It looks the same way it did the day it came out of the box last spring. My engine was balanced wrong and therefore i was forced to pull the motor. I got to drive it up and down the street twice. I am now going with a crate motor for my project instead of the original 327.
Lunati Hydraulic roller camshaft part number 501A3LUN. I paid a total of 289.00 for the camshaft from summit racing. Keep in mind that Roller cams dont go bad and there is not a break in period for them. Shipping will be 12.00. Specs are listed below. .
Camshaft specs
Part Number: LUN-501A3LUN
Cam Style: Hydraulic roller tappet
Basic Operating RPM Range: Idle-5,500
Intake Duration at 050 inch Lift: 218
Exhaust Duration at 050 inch Lift: 218
Duration at 050 inch Lift: 218 int./218 exh.
Advertised Intake Duration: 284
Advertised Exhaust Duration: 284
Advertised Duration: 284 int./284 exh.
Intake Valve Lift with Factory Rocker Arm Ratio: 0.492 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio: 0.492 in.
Valve Lift with Factory Rocker Arm Ratio: 0.492 int./0.492 exh. lift
Lobe Separation (degrees): 112
Quick Reply: Lunati Retro Fit roller camshaft
