RICHMOND 5/6-speed kits...
Okay...sorry this is drawn out,but trying to figure out the best way to advertise these kits,and what is available.
I just became a dealer for these Richmonds,so please work w/me alittle in the beginning.
I ran a old Doug Nash 4=1 in a Camaro many moons ago,and loved it,and leaning t'wards installing one of these in my 68.
I have done some extensive search on the internet,and this forum on these,and the install of these transmissions in Corvettes.What makes these nice is the gear selections available w/most of these trans.They fit the vette tunnel better,can be used w/all of the existing parts,except the custom made trans brackets that I am including,and the need for the original style "big turbo 400 yoke".These are all included w/Long shifters,and by all my research...are superior to the Hursts that are available for these trans.These will fit the stock shifter hole,and there is no need to modify the crossmember,nor does the driveshaft need shortened,so you can use the one that you have.Also,these are idea for the 3.08 cars,and 3.36s,and if you have higher gears,then cheaper to change the trans gears when ordering,than changing the rearend gears.
I have had some phone calls about these,and pms,and wanted to get this up,and available,but will be adding the complete conversions for the auto to manual conversion,and as always....I have scattershields available,performance clutch kits for ANY horsepower setups,Hyd. clutch/sl;ave setups,aluminum flywheels,steel,billet,LS1 flywheels,bellhousings,etc.I', more than willing to work w/you,and put together a kit for you.That's not a problem.
Until I get all the extras together,and posted..if someone is interested,then please pm me,and will get you taken care of.
I am still selling the TKOs,and they are GREAT transmissions,but I ran one of these,and was very pleased years ago,and these have been around for along time,and made right in SC.I just wanted to be alittle more versatile,but sold a TKO kit today.
All the trans will be shipped directly from Richmond,and all trans have a 1 year manufacturer warranty.
One more thing...as much as I hate to put this in words...I can beat Summitt,and Jegs on all these kits,and the additional items in the kits,except for the 6-speeds.They apparently buy in BULK,and are a couple hundred cheaper than me,so I would shop there,if you are wanting to go this route.I will sale you the "extra" parts needed to get this in your ride tho'.If I can do okay w/these,then the pricing will come down further,but right now they are cheaper on this one item.
*STREET 5-SPEED KIT*
A ratio=3.28,2.13,1.57,1.24,1.00
Kit consists of... "Street 5-speed" trans w/ Long shifter,Corvette strap style 32 spline yoke,modified trans bracket,new trans mount,needle roller pilot bushing,new u-joint,and shift plate indicator...
#52110AL-GM 26 spline...$3350.00 shipped
#52111AL-GM 10 spline...$3350.00 shipped
* SUPER STREET OVERDRIVE 5-SPEED KIT*
1st gear(your selection),2nd-1.85,3rd-1.31,4th-1.00,5th-0.77
Kit consists of..."Super Street 5-speed"trans w/ Long shifter,Corvette strap style 32 spline yoke,new u-joint,modified trans bracket,new trans mount,needle roller pilot bushing,shift plate indicator,back-up light switch,and wire...
#7020526A-GM 26 spline w/3.33 first gear...$3850.00 shipped
#7020526B-GM 26 spline w/2.89 first gear...$3850.00 shipped
#7020526C-GM 26 spline w/3.06 first gear...$3850.00 shipped
#7020510A-GM 10 spline w/3.33 first gear...$3850.00 shipped
#7020510B-GM 10 spline w/2.89 first gear...$3850.00 shipped
#7020510C-GM 10 spline w/3.06 first gear...$3850.00 shipped
*ROAD RACE 5-SPEED KIT*
Kit consists of ..."Road Race 5-speed" trans w/Long shifter,Corvette strap style 32 spline yoke,modified trans bracket,new trans mount,needle roller pilot bushing,new u-joint,and shift plate indicator...
#52226AL-GM 26 spline...$3526.99 shipped
#52210AL-GM 10 spline...$3526.99 shipped
*custom gear ratios available....add 190.00*
custom ratio selection guide for the RR 5-speed...
1st gear...4.41,4.06,3.28,3.04,3.01/2.77/2.24/2.08
2nd...2.75 1.88
2.45 1.67
& 2.22 1.52
2.13 1.46
3rd 1.99 1.36
1.57 1.07
4th gear...1.24/.084,1.52/1.04,1.74/1.19
5th gear...1.00
*6-SPEED OVERDRIVE-ROD KIT*
AA ratio=3.28,2.13,1.57,1.24,1.00,.76 OD
Kit consists of..."ROD 6-speed" trans w/Long shifter,Corvette strap style 32 spline yoke,new u-joint,modified trans bracket,new trans mount,needle roller pilot bushing,shift plate indicator,speedo adapter,back-up light switch,and back-up light switch harness...
#7021626AA-GM 26 spline...$4100.00 shipped
#7021610AA-GM 10 spline...$4168.00 shipped
*custom gear ratios available...add 190.00*
custom ratio selection guide for ROD 6-speed...
1st gear...4.41,4.06,3.28,3.04,3.01,2.77,2.2 4,2.08
2nd...2.75 1.88
2.45 1.67
2.22 1.52
& 2.13 1.46
1.99 1.36
3rd...1.57 1.07
4th...1.24/0.84,1.74/1.19
5th...1.00
6th...0.76 0.52
0.81 0.55
0.86 0.59
0.91 0.62
Special 9 DP RR ratio...0.84,or 0.80
*auto to 5/6-speed conversion...
Mechanical linkage...$1033.20(shipping included)
Hyd.linkage setup...$1200.00(shipping included)
parts list of conversion for mech.linkage.If ordering hyd.setup...parts are substituted...
1.trans tunnel shift boot
2.brake.clutch pedal pads
3.cross shaft
4.cross shaft rebuild kit
5.frame bracket
6.clutch fork
7.clutch fork pin
8.clutch fork push rod
9.clutch fork push rod anti-rattle springs(2)
10.clutch pedal push rod
11.clutch pedal push rod swivel
12.clutch pedal push rod jam nuts(2)
13.clutch pedal push rod firewall boot
14.firewall boot retainer
15.pedal return spring
16.clutch pedal
17.brake pedal
18.clutch pedal bracket bolts
19.clutch pedal bracket
20.clutch pedal bumper
21.clutch pedal bumper bracket
22.clutch pedal shaft clip
23.clutch pedal push rod spacer
24.clutch spring firewall bracket
25.brake/clutch pedal bushing
26.brake pedal spring bushing
27.shift boot retainer
28.shift boot retainer screws
29.4pk "G" clips
30.11"#621 repopped bellhousing
31.11" inspection cover
32.inspection cover screw set
33.clutch fork boot(GM)
34.bellhousing bolts(6)
35.bell to trans bolts(4)
36.flywheel bolts (6)
37.pressure plate bolts(6)
38.11" flywheel
39.11" perf. clutch kit
additional parts available....
Corvette style shifter handle...$85.00
Hyd.clutch linkage assembly...$450.00
McLeod scattershield...$375.00
CF dual friction clutch kit...$389.00(400-500 horse)
CF 12" dual friction clutch kit...@410.00(500-600 horse)
McLeod 600 series clutch kit...$375.00(350-400 horse)
McLeod 800 series clutch kit...$375.00(400-500 horse)
Mcleod RST street twin clutch kit...$710.00(550-700 horse)
Mcleod RXT twin clutch kit...$810.00(750-1000 horse)
64-67 finished console painted w/inserts...$500.00(480.00 w/kit)
64-67 chrome console...$375.00(350.00 w/kit)
I want to offer a big THANK YOU to drlou over in the C2 section,sky65,buddydeberry,Hotrod427,and all the other guys that have answered questions,provided pictures,and thoughts,etc.Thanks guys.
If you have any questions feel free to pm me,or give me a call.
Kevin Gilliam
Vettes by Design
217.330.7425
2nd...2.75 1.88
2.45 1.67
& 2.22 1.52
2.13 1.46
3rd 1.99 1.36
1.57 1.07
5th gear...1.00
2nd...2.75 1.88
2.45 1.67
2.22 1.52
& 2.13 1.46
1.99 1.36
3rd...1.57 1.07
5th...1.00
6th...0.76 0.52
0.81 0.55
0.86 0.59
0.91 0.62
3.cross shaft
5.frame bracket
6.clutch fork
7.clutch fork pin
16.clutch pedal
17.brake pedal
29.4pk "G" clips
38.11" flywheel
Kevin Gilliam
Vettes by Design
217.330.7425
I guess this kit is for C2 and C3? I tried to read the entire post but might have nodded off.
I installed a Richmond 5 speed in my 57 with good results. It's the same lenght as a T10/Muncie and has loads of room on the top side. I made my own cross member and shifter mounting bracket to lower the Long linkage.
With the 3.27 low gear and 3.08 rear end it always has the right gear at the right time!
Sorry that ya nodded off.My little computer girl went back to college,then the economy went south,so....it's me,and my master skills on this cyber crap.
What sort of horsepower/torque are these transmissions good for? My engine is supposedly putting out 620HP/650 ft.lbs. at the flywheel, car weighs about 2900#, 3.45 rear axle ratio, running street tires now but may go to 10" drag radials.
Charles
Charles
Received 1,240 Likes
2022 Corvette of the Year Finalist -- Modified
2021 C2 of the Year Winner - Modified
2021 C1 of the Year Winner - Modified
2020 Corvette of the Year (stock)
C2 of Year Winner (stock) 2019
2017 C1 of the Year Finalist
Kevin,
I've seen a few comments regarding modifying the shifter mounting bracket inorder to lower it so the shift handle does not sit so high. Can you comment on this and do you offer the modified bracket?
Thanks,
Rex
Thanks,
Rex
I will reply to the above later,or in the AM.I have a customer here from way up by Canada to pick up his 69 convertible,and he has been here for a couple days,and haven't been on here.He is leaving this AM,and things will slow down alittle,and will address the questions above.Sorry....
Yes...I can get the Long shifters seperately,and will get you the price.
To the guy wanting the complete conversion.....I will get the price for the complete conversion.
Rexx.......I haven't done the install in the mid-years,but I have seen where they modified the shifter mount.Do a search,and look at Sky65 blue mid-year.He has the standard Long in there.Pretty nice fit.
I will get ya all the prices,and answer the specific questions later.
Again....sorry for the delay.
Kevin
Kevin
The Super Street 5s are rated at 600ft/lbs of torque.
Rex.....do do the search for the Richmonds.I got linked to a web page where from here on the forum where a guy did modify the shifter mount to lower the Long shifter.I believe 427Hotrod commented in a thread inb te C3 tech section,and linked it to the guy w/the mid-year install that modified the mount.If you can't find it....pm me,and will try to get the link some how.I should have saved it.
You are welcomed to give me a call...217.330.7425.
Kevin
I also,sell the TKOs.....you might want to do a search there also.Type in TKO in the search engine,and you will see my posts for the Tremec conversions.They are alittle cheaper,but not much.
Charles.....there is a guy over in the C3 section by the name of 427Hotrod,and he is putting out some serious numbers w/a BB,and uses a DN/Richmond,and swears by them.He has like a 11 second car that he drives EVERYWHERE,and races it every chance he gets.Do a search for Richmonds.
Charles
There's another comp. that sales trans called tranzillas,or something like that that you may look into,bud.I think they are rated to 1200 horse!WOW!!!!!
