2 X 4 Intake and Carbs
I have an original Dual Quad Intake with Carbs that I need to sell. The Manifold has never been modified, it also has no cracks and has not been welded anywhere. One Carb is disassembled the other is not. I have all the components. I have the rebuild kits for the Carbs.
The casting number on the manifold is 3739653, the numbers on the top side of the Carbs are 6-1299.
I am just outside of Chicago. NW Burbs.
I have been told that this set-up is worth at least $2,000.00.
But that can be discussed.
I have posted pictures at the site below...
http://s446.photobucket.com/albums/qq186/terabyte47/
what all is missing besides the choke and the one throttle rod piece? it also looks like the one top is just sitting on there with no screws holding it in place.Is there a pan cover on the bottom of the intake? any cracks,repairs or bad parts on the intake? how is the thermostat housing part of the intake? where are you located?
Received 1,283 Likes
You might want to check the archives to see if these are 245 or 270 hp carbs. Apparently there is a significant difference in value between the two types.
I don't know enough about them to be able to point you in the right direction. This discussion came up recently, so there should be some info available.
Try this link
http://forums.corvetteforum.com/c1-a...ight=2x4+carbs
Try this link
