Special High Performance 67 Corvette 327ci. engine
5th Gear
Special High Performance 67 Corvette 327ci. engine (short block , heads, lifters, some tins,water pump, )
This 1967 Corvette 327ci short block and the 462 heads offered up are completely rebuilt and ready to go. No expense was spared, as all the wear parts were replaced on the rebuild of this engine. The short block and heads have been professionally rebuilt and assembled to factory specifications by “Northeast Machine” in Tonawanda NY, included in the rebuild were new standard pins and pistons. This block has never been decked, and retains the original HT Corvette suffix code stamp. The heads were rebuilt using all new parts including stainless steel valves, and hardened seats to run on unleaded gas. If you want pics, or have any questions, let me know. If you forward you email address to: javrest@msn.com. I’ll send you pictures. You can come and look at it if you wish Virginia Beach 23451). I can deliver it to a local shipping dock and you would pay the freight when you pick it up, you can pick it up here if your close enough, you can arrange shipping yourself, if you wish. The buyer will be responsible for all shipping costs. My price is firm at $2,200.00.
· The block casting # is 3892657 that is dated D 11 7 (67 327ci) with a origional suffix code stamp of V04I3 HT stamped into the head pad. (Corvette Special High Performance)
· The heads casting # are 3890462 (camel hump, no accessory holes, 64cc) with dates D 25 7 and A 16 7
· I have Oil pan, timing chain cover, crank damper (new), and water pump dated
C 31 7. and a gasket kit that will be included in this sale.
