FS - C1 56 to 62 NOS, USED, & NEW Parts
Pictures HERE on Photobucket.
Selling my inventory of stuff I collected for the last 4 years for my 62 project which sold. I was going to go to the auction site but frankly I hate paying those darn fees. It's about 9%-10% now! Rather than charging more for the parts, selling here will save you that.
You pay shipping. I have a Fedex account and you pay what I pay. I will ship as soon as possible after payment.
edit 3/10...Personal Checks are ok but please understand you'll have to wait about 10 days for clearing time. US Postal Service Money Orders are best. They are cleared right away and can be cashed at the PO. I can take Paypal but you must add an additional 3% of the total cost including shipping.
Please email me directly using my website "Contact" page. Please put "CFFS - Part Info" in your email Subject Line so I can keep track of it easier for both of us. It will send me a direct email and I will reply to your email address directly. If you send me a PM(Private Message) I will reply to that but remember pictures cannot be sent through PM's. PM's are ok for initial contact but it's cumbersome for this kind of stuff.
If the link doesn't work for you Firefox folks go here then to the "Contact" button.....
http://home.comcast.net/~richmz
To search thes list below in your browser hit "Ctrl F" then type in what you're looking for.
Also, If for any reason you are not satisfied with anything at all just email or call me. If your concern is valid or if I made a mistake I'll refund your money. If you made the mistake please understand you must pay return shipping yourself. If I made the mistake I will pay your return shipping cost using a Fedex return label emailed to you from my account and give you a full refund including your initial shipping cost.
Thanks,
Rich
I will try to get back to emails asap but I have 2 projects going on right now. Please be patient with me.
Here goes........
Used Big Stuff
Frame & Xmember pics Here:
1962 Frame, including rear axle, brakes/drums(& 2 roller wheels/tires), original springs, radius rods, rear sway bar, etc. Less front crossmember. The pics are a few years old. The frame has been outside and is weathered. There were, and still are some rust spots as can be seen in the photos, likely more. It is setup for Meyers, or use with C1 susp with a little re-work(cut side brackets welded to frame & add upper L-brackets for stock front engine mounts. $2700.00New price.....$2150
C1 Front crossmember drum to drum, came from a 62 restomod project in FL, very nice condition $550 New price.....$450
Four Brake backing Plates with Pins installed $180
Smaller Stuff
NOS Parts- Most in original GM boxes/wrappers:
58-62 Grille Upper Center Molding, in box, GM# 3799991 very nice $350
1962 Side Rocker moldings, 2 - Sold
1962 Front Grille $400
58-62 Park lights, left & right $200 Sold
61-62 Headlight bezels, 2 $135 Sold
61-62 Headlight bezels, 2 (no boxes) $135 Sold
61-62 Headlight bezel chrome tips, 2 $50 Sold
58-62 Chrome outer eyebrows, 4 $300 - Sold
58-62 Deck lid latches, 2 $275
58-62 Lower windshield Stainless trim $425 New price.....$350
58-62 Directional Signal cancel cam $75 - Sold
58-62 Clutch fork retainer $10 Sold
58-62 Directional switch w/ correct strip harness(old blk/blu box w IBM punchcard nos, box dated 0332C3 (march 1973?)) $50 - Sold
58-62 Directional switch w/ loose wire harness(not old nos, wht/blu box nos) NLA
58-62 Radiator support pad $10
58-62 Door handle gaskets, 2 $10
58-62 Headlight bucket retainer hardware, 2 sets $35
58-62 Headlight Buckets complete with dogdishes, ss trims, NOS T3's(missing 1 outer T3 bulb. T3's are non-dot 62 bulbs) $450 New price.....$350
58-62 Bumper Seals, front & rear, 6 $100
58-62 Front License bar lower $50
58-62 Front License back plate - Sold
61-62 Inner tail Lights, L & R $250 New price.....$200
61-62 Outer tail Lights, L & R(yes nos!) $350 New price.....$300
58-62 Temp Sender(correct "USA" marking) - Sold
58-62 Generator harness $35
61-62 Ignition shield RH vertical$75
58-62 Tie rod ends, 2- $90 (service replacements)
61-62 Expansion tank(undated)- Sold
58-62 Gas cap- Sold
58-62 Window Crank handles, 2 $240 New price.....$100 each
1962 Front Emblem $65 edit 3/16 I had this originally marked as 58-62, sorry for confusion
62 Side emblems, 2 $100
1962 Cigarette lighter(casco) $75
58-62 Wiper bezel gaskets$15
58-62 Dimmer switch(correct top)$50
58-62 Door lock *****, 2 (early NOS, not late nos)$90
58-62 Engine harness, manual trans (correct small diameter loom for temp wire)- Sold
61-62 Radio *****, 2 $50
61-62 Headlight switch & ****$75
61-62 Red trunk mat(correct embossed pt#)- Sold
61-62 Conv top bow W/Strip $45
62 Front Letters (CORVETTE)- Sold
58-62 Shift Plate Console $90
58-62 Shift plate (4 Spd) $25- Sold
58-62 Shift plate rubber boot $35
58-62 Emblem & bezel kit, Silver, (aluminum back-plate) $115 Sold
61-62 Battery J-bolt, 1 (can't find it?) $15-NLA Used it on the '63, arghhh!
62 Tach Boot in engine bay $45
59-62 Center Side window Soft top W/Strips, 2 $35
58-62 Ashtray (AAC) but black ****, you can buy chrome **** & swap) $95
58-62 Dash & Forward main wiring harness w/ fuse block, nice, orig box $475 NLA
61-62 5 Dill tire valve stem caps $20
62 Ignition switch(1116577 D-1493) $75 - Sold
61-62 Antenna complete, correct with brackets, gnd strap, escutcheons, etc. Used lower tube but I found a better one than what's pictured. "WARD" & Bowtie - Real! $350 Sold
61-62 Armrests, red, 2 $100
58-62 Qty 2 Pt# 3762678 Front Window Runs(SS & Felt Channels) $115
58-62 Clutch Spring on frame to clutch cross shaft $45
62 Carb to Intake Accelerator spring(Green -for 250hp) $15 Sold
56-62 Door Window Seal Fuzzies (both doors) $150 - Sold
61-62 Interior Mirror(vintage OTC service replacement) $100
(yes there are 2 mirrors)
61-62 Heater **** $25
Used Parts/ Some Restored Used Parts:
58-61 Side Cove molding, pair L & R, will need some dings removed and polishing $100
58-62 Grille Lower Center Molding, about 50 pits, nice core for re-chrome GM# 3799993 $80 Sale Pending
1962 Wonderbar Radio and Bezel. Early 62 configuration $850 New price.....$750
1962 Horns, 441 & 442 (1 works, both need rebuilding/restoration?) $375 Sold
1962 Radiator Support Nice Original, stripped, light surface rust, missing lower spacer plate but new repro included you can weld on $375
1962 Distributor for 250 HP (1110984)- Sold
1962 Antenna Cable(correct knurled connector(1/2" ID), white "WARD" stencils) $85
195?-196? Distributor Ign Shield top. Generic Service Replacement. Kinda' like '61, definitely not '62. Nice condition, not perfect, with a few little dings and a few scratches - NLA
1962 Rear Conv Top latches(on bow)- Sold
Original 1962 Sales Brochure & repro window sticker $40
58-62 Rebuilt Heater valve (original 3139127 stamped) $100
61-62 Re-plated Expansion Tank Bracket/Strap/original bolts, original correct hose clamps, original #8 hose clip, etc("A" on strap)This is the real thing, Complete! $225 New price.....$185
1962 Exhaust Manifold (9965 restored) $100
58-62 Door handles(2, originals rechromed) $125 - NLA
59-62 Grab bar ends(2, originals rechromed) $75
58-62 Center Console Lower Chrome trim(rechromed)- Sold
58-62 Speedometer bezel(rechromed) $85
58-62 Clock (restored) $150 No Longer Available......Not working right. Arghhh!
58-62 Tach bezel (rechromed) - Sold
1962 Lug wrench (correct restored "O" mark and bent tip) $95- Sold
58-62 Oil filter Cannister (restored)- Sold
1961/ early 62? 1107889 Used Starter (1M8) Dec 8, 61 date, with auto or manual trans(2 noses inc) $150
1961/ early 62? 1107889 Rebuilt Starter (1G11) July 11, 61 date, manual trans $150
58-62 Seat belt brackets, outer, 2 $45
58-62 Radio Support bar $20
61-62 Trunk latch (restored replated) $75
61-62 Windshield Washer bottle (complete ,gray top but blemished with a few small pieces missing, nice pump condition) $225- Sold
59-62 Shifter, reverse lockout, 4 speed original with new chrome shaft, correct white threaded ****, linkage $400
58-62 Convertible top front header latches, rechromed faces, included adjust plates & screws- Sold
59-62 Package Tray(black)- Sold
62 Valve Covers, 2(small rib, restored, with decals) $175 New price.....$125
58-62 Restored Red Steering wheel and hub, complete- Sold
59-62 Horn Button, nice original $65
58-62 Mirror, Guide Y-50 original(needs restore) $55 pics added 3/10
58-62 Mirror, Guide Y-50 Reproduction Pictured by Mistake - oops not for sale
58-62? Ballast Resistor 1.8 Ohm (with break-off tab, spot weld & Delco Remy stamp) Not Corvette but it's a nice functional period correct clone. $40
58-62 Gas Pedal $35
62 Hardtop Wrench (not "Vlcheck") & bag (correct) $50
58-62 Left Door window Regulator(Needs gear replaced,..included) $150
58-62? Vacuum tank for W/S Wiper system(broken studs) $50
62 Original aluminum radiator drain tube and hex adapter for petcock $45
62 Tach(low horse) - $250
62 Small Gauges(both sides) $300
56-62 Fresh Air Intake on Firewall, chip under where hose goes $65
62 Restored original black steel back-plate for rear emblem $45
New GM parts:("Newer" NOS)
58-62 Interior mirror Support $50 Sold
58-62 Front Emergency brake cable $45 Sold
58-62 Spark plug shields, These are not offshore.Real GM parts, very expensive OTC service replacements - all 4 pcs $75
Reproduction(new) parts:
1962 Positive & Negative Spring Ring battery Cables LL(correct) $80
1962 Side Emblems $54
58-62 Top Fender Moldings, 2 $200 Sold
58-62 Headlight harnesses, 2 $55
Dewitt's 1962 dated aluminum radiator(H61 or 61H I forget) You can get new dated plate if needed. $750- Sold
Al Knoch 1962 Dated(9-61) Black Soft Top Kit $350
Just Found! 1956 to Early 1959 Original Door Weatherstrips. Has a few "Diamonds" embossed. Hard to see but there. 3 pieces total. Some areas are crackly from age but extra pieces can be glued in to replace questionable areas. Original wrappers(rough).
2 lefts & 1 right. $300 (pics added 3/17)
56/57 Stuff
Pair of 56/57 Tail Lights, Rechromed, Nice $675 New price.....$575
56/57 Rechromed Original Grille Bar $125New price.....$100
56/57 Windshield Cowl Vent $85
56/57 Windshield Cowl Vent Hinge Set (different from 58-62) $65
56/57 NOS? Park Lights, much shelf wear, has sockets but no harnesses $150 - Sold
56/57 NOS Air from Non-DOT Original Spare Tire.... $Priceless(ha ha gotcha)
endoflist
3/24/11 am : sold pk lights & emblem kit
3/18/11 am : added 58-62 grille center moldings & 58-61 cove moldings
11/8/11 sold hdlt bezels, tips, antenna
2/13/12 sold washer bottle
Thanks,
Rich
Here goes........
Used Big Stuff
Smaller Stuff
58-62 Gas cap- Sold
58-62 Gas Pedal $35
56/57 Stuff
endoflist
Frame & Front Crossmember photos
Frame & Front crossmember pics here. The pics are a few years old. Front crossmember looks the same, stored inside. The frame has been outside and is weathered. There were, and still are some rust spots as can be seen in the photos, likely more.
http://s684.photobucket.com/albums/v...ont%20Xmember/
PM sent...
Thanks everyone for the overwhelming response.
I'm pretty sure I've replied to all emails and PM's. If I missed anyone please send me a reminder.
Rich
p.s. I am getting closer to the C2 possibility. When I get a chance I'll show you the "driveway" find over on the general forum that I'm trying to get. Don't worry I'll never sell my '59. I love C1's but really miss our silver blue 63 swc that we sold a year ago.
Rich
BTW this is the C2 I found......Factory A/C 63 vert loaded, power everything! Please buy all of my 56-62 stuff...... so I can buy it and '63 stuff! I'm gonna' need a lot of stuff.
Rich
Rich
Rich
Rich
Best regards, Hotchrome
Drove to Rich's place in the '61 (a 200 mile round trip down the East Coast of Florida) and picked up my C1 NOS outer grill eyebrows...still in the box ! Man are they nice....all his stuff is the 'real deal'.
Got to see the BB conv he's building for an overseas customer. Awesome doesn't start to describe it...427 tri-power and all the right numbers everywhere.
So this is the sister to your Silver Blue Baby. When I found it I thought of you immediately. The Same Color! What are the chances of that.
You'll have to post some pictures here of your '63 in your garage like the ones you sent me a while ago. And also some of the '58.
All the Best,
Rich
Hi Mark, I replied to your direct email request through my website to your direct email address and sent it to you on 3/10, the same day you emailed me. Maybe you missed it?
As I said then, I updated the photos on the PB page right away. They are in the first page of photos, 14 photos total, the 7th to 20th pics.
Here is the full link again.....
http://s684.photobucket.com/albums/v...%20for%20Sale/
Regards,
Rich
Well......you gotta' see Franks '61 close up. It's absolutely gorgeous! It's got those dual fours just like my '59 has. Great minds think alike hey Frank?
Those 4 NOS eyebrows found the right home. The nice thing is they'll fit perfect too! Nothing like real deal GM parts.
Thanks for the nice compliments on my work on the '67 427/435 vert. Here are a few pics.....I love working on this car. I kid around with the new owner I'm gonna keep it! He's a great guy, and came over for 2 weeks in January with his family and Corvette buddy to work on it with me and do the Kissimmee Corvette and tourism events. He has a C5, and has built two, yes two pro-stock cars in the past, a 57 Chevy and a 69 Camaro. He loves American cars!
It's always a pleasure meeting people from overseas. We had a great time playing with cars and doing Florida tourist stuff. We even went on a airboat ride nearby. My first time too and we all had a blast. Even saw a BigBlock Aligator!
Just wanted to say that I got the radiator and cancelling cam from Rich and the items were perfect and just as described. Shipped fast and a great guy to deal with. Thanks Rich.
Bill VO
Bill VO
