Intake manifolds--1x4-3x2-original +
Former Vendor
Okay Forum,
Here's another link to my photo bucket----this one is of intake manifolds.
All are Aluminum, factory original, plus 1 over the counter GM, and a few aftermarket items.
Link---http://smg.photobucket.com/albums/v663/435rdster/Intake%20manifolds/---Link at end of post is working.
'65 3866963----$450.00----Plenum cut--396/425hp Corvette and Chevelle
'66 3885069----$550.00----Perfect--- 427/450hp Corvette 3 hole plenum
'66 3885069----$500.00----Perfect----2 hole plenum for '68 427/425hp Camaro and passenger, but outward appearances pass as '66 427'450hp Corvette
'67 3886093----$500.00----Perfect---Corvette L88 427/430hp
SOLD---'67 3890490----$500.00----Perfect---327/350hp---SOLD
Sold----'67 3890490----$350.00----bit of corrosion at thermostat,but it does not leak.---Sold
Sold----'67 3894382--$2,000.00----Perfect---Original, not one of the new re-pops---3 x 2 oval port 427/400hp--sold
I do not have any more 382"s or 374's
Sold---'67 3894382--$2,000.00----Nice------same as above---Original---Sold
Have matching carbs for above intake dated September of 1966, and original air cleaner, also some original '67 "smog" valve covers that have been chromed.
'67/'68 3917610---$550.00---Perfect---Camaro Z28 302/290hp
Sold---'68 3919849---$350.00---Nice----427/390hp 1 x 4---Sold
Sold---'68 3919849---$450.00---Perfect---As above---Sold
Carb has been SOLD-----Have the original matching Q-Jet for the above manifold---427/390hp--7028209FG--dated rather late in the '68 production run---Carb is SOLD--$1,000.00--SOLD
also have the original air cleaner and filter, exhaust manifolds and------
Ta Da,
drum roll please,
the Original, complete A.I.R. (smog) system--evey piece, all as it left the factory, dated, stamped, original marked hoses, etc., etc---$Expensive.
Actually have the complete engine----everything---$Inquire. Now have this engine listed for sale in another post (complete minus carb, or part out)
'68 3919852---$1,149.00---Nice---Corvette 427/435hp 3 x 2
'69 997 rec. port, very nice---$1,350.00
Have a couple of Hi-Per 3 x 2 air cleaners
SOLD----and a matched set of 4speed 3 x 2 carbs dated March of '68---Carbs are SOLD
Sold---Might have another 852--need to check. ---Sold
SOLD --'68/'69 3933163---$600.00---Perfect--- 427/425hp Camaro/Chevelle---SOLD
'68/'69 3933163---$300.00---Perfect---427/425hp---GM over the counter replacement.
SOLD---'69 (and very late '68)---3937797---$1,400.00---Perfect--427/435hp Corvette---SOLD
Forgot about this one--Winter's snowflake, Big Block, Rec. port, but I cannot find an application for it? Prototype/racing/Marine?
Also have a nice Offenhauser small block Chevy side by side 2 x 4 aluminum intake (it has '66 Mopar carbs on it)
Have some small and big block cast iron intakes also--'57 thru '68
Have some 1 x 4 Hi-Per air cleaner bases and lids, steel and aluminum valve covers, timing covers, oil pans, dip sticks, etc.
Also have oval and rectangular port big block heads---208's ($1,995.00), 391's ($1,500.00 to $2,500.00, 840's ($900.00 to $1,500.00, 802's ($450.00), 063's, 290's, 291's--Also aluminum 392's ---Two sets (1,500.00 and $2,500.00), and 842's ($1,950.00).
Have some TI distributors/amps/harnesses
Please see all of the manifold photos in my photobucket http://smg.photobucket.com/albums/v6...e%20manifolds/
Thanks,
George
210 748 4693
geopar@gvtc.com
Ta Da,
drum roll please,
Thanks,
George
210 748 4693
geopar@gvtc.com
Former Vendor
Adding this one:
1965 327 350/365HP
Includes the chrome filler tube and cap.
Put this together with the air cleaner offered in another of my posts and you're on your way.
Thermostat area has corrosion, but thermostat still seals.
Otherwise a very nice, original Winters snowflake aluminum manifold.
$375.00
Thanks for looking,
George
geopar@gvtc.com
219 748 4693
1965 327 350/365HP
$375.00
Thanks for looking,
George
geopar@gvtc.com
219 748 4693
Gm #3890490
I am looking for a manifold for my 1967 Corvette, small block. Prefer one with no repairs.
Call Bill at 928-203-0430 or email me at w.spring@yahoo.com
Thanks,
Bill
Thanks,
Bill
