Want to Trade 58 hardtop for 59-60
I have a 60 vette I am restoring. It came with a 58 hardtop. I started to restore the hardtop and had it apart before I realized it was a 58 top. I would like to either trade tops, or if someone has a 59-60 top apart, trade the stainless pieces to swap from a 58 to 59-60.
Thanks,
Don
Thanks,
Don
Cruising
H/T trim
Thanks,
Don
Thanks,
Don
2023 C1 of the Year Finalist - Modified
Thanks,
Don
Thanks,
Don
Hardtop
Does your top have a small Y shaped stainless junction piece between the rear window and the side window down at the bottom ? If it does it is 57-59 if it dosn't and it just has two long mouldings that start at the door and meet in the bottom center of the back window it would be 1960,,So that is the 57-59 top has 3 pieces of stainless at the bottom,,Where as the 1960 only has 2 really long pieces that meet in the back.
Thanks 60 Fleetside. I do have the 3 pieces of SS molding on my 59. Glad to know I have the correct top for it.
This Forum and the guys and gals on it is the best!
Not to confuse things but I am of the understanding that all 56 to 58 tops are the same except for the narrow header on very early 56 tops and the 59 and 60 tops are identical without the Y molding on the side at the bottom and then 61 and 62's are the same except for headliners of course on all of the different years.
Vertical pieces out outside edges of the rear window are different. 58 had one piece lower rear window outer trim, the 60 has three piece, two sides and a center connector piece. Also, the 58 has the "Y" piece to tie the rear winder vertical pieces to the lower trim.
So are you saying that if I trade these trim pieces, the 58 can not be modified to be a 60 top?
Also, it was my understanding that the tops where actually changed in the 59 model year, so that there are early 59 tops that are like the 58 and later 59 tops that are like the 60.
However, I only know what I read. No first hand knowledge.
