Comp Cams Roller Cam Springs, Locks, Retainers
SOLD
50.00
This will fit standard cast heads
A few years ago I had a roller cam in another engine with edelbrock heads. I bought these springs for the small block chevy edelbrock heads to run with my comp cams roller cam. I used the engine for around 800 miles, but then ended up selling the car and both of its engines. The new owner did not want the heads off the extra engine, so i removed them, put them back to stock and sold them. I held onto the roller cam and springs for future use.
Part number 986-16 Price New: $84.95
Price of 10 Degree Retainers: 52.95
Price of 10 Degree Locks: 22.95
Total new: 160.85
ASKING: 80.00 Plus shipping
Seat Load 132lbs
Spring rate: 322 lbs/in
Coil Bind 1.150
Diameter of Spring 1.430
http://www.summitracing.com/parts/CCA-986-16/
50.00
Total new: 160.85
Seat Load 132lbs
Coil Bind 1.150
Got your PM. The box was turned over in the attic and 3 of the internal springs are missing. I am going to be forced to clean out the entire attic to locate them. Ill report back once i find them.
