Lots of parts headed to Carlisle
Time to clean out the garage. Heading to Carlisle and here is a list of some of the things I am bringing. Stop by and see me in spot D29 and D30.
NOS parts
Rear spring bushing washers $2 pair (2 sets)
Pinion bracket thru bolt 3846867 $7
7 AC 45 3 ring spark plugs $3 each
PS control valve hose $5
Brake bleeders 7 for $8
Top radiator cushion $3
Side pipe cover support brackets 3876556 $2
Horn lock tab $15
Block clutch ball and felt $5
½ shaft locking tabs 4 for $3.50
Brake pedal return spring $5
Rear end filler plug 3866433 $6
Strut rod adjusting bolt and cam $5
New Repo parts
Tail light gaskets (4) $5
battery cover $ 25
Frame end plates$3
Tie rod ends Moog ES323R (2) $12 each
Trailing arm bushings $8
Fuel tank sender o-ring and lock $3
Strut rod bushings $8
Rear inner spindle seals 9178S (2)$2.50
PB master cylinder rebuild kit Wagner $5
PS control valve rebuild kit $8
PS pump repair kit $10
Special parts
1 TI ignition modules $150 each
1 TI module converted to HEI,w original internal parts $125
T-3 high beam headlights W/bucket & trim $35 each
Low beam headlights new $7 each
Firestone deluxe champion 7.75x 15 NOS (has dot) $100
Fan blade, 35 degree round rivet 18 inch 63/64 & 66/67 w/AC $100
Trico wiper arm brushed SS $70
Steering Hub 1968 $110
1963 Parts
824 Horn relay $40
Water pump 608 E1 date $60
Fuel pump 4657 $75
087 coil $50
Rear spindle, drum brakes $35
*****, cigarette lighter, wiper turn signal $10 each
Door handles raised style cores $10
Rear exhaust hanger with correct bolts $20
Classic parts
Door handles, window cranks, lock **** $5 each
61 Owners manual 2 edition Not repo
generator tac gear
Engine
Valve cover retainers $3 /set
Oil canister adaptor $10
Air cleaner covers (2) open element type $25 & $50
65 idler pulley assembly $75
Expansion tank straps $5 pair
Left ignition/ spark plug wire shield bracket $10
Exhaust manifold left pt no 49965 $75
PCV valve AC5649561 $10
Accelerator Rod $7
Alternator pulley 64/65 250/300 hp $20
Single groove H2O pump pulley $15
Rear end parts
[/B]½ shaft U-bolts 4 for $8
Drive shaft U-bolts 4 for $8
Disc brake rear spindle $35
Rear Sway bar links $15
Pinion bracket with supports $20
Strut rod bracket early and late styles $10
½ shaft outer flange $15
New ½ shaft u-joint $10
Cross member bushings $75 pair
!/2 shaft drive flange $10
Automatic Pinion Flange $10
Outer Spring bolts 3 for $5
Spring center retainer plate $10
Interior Parts
Hood release lever and cable $20
Door hinges $50 pair
Door striker plate assemblies $75 set
Deck lid latches, strikers center lever & rods $100
Door wedges set 6 (3 al 3 plastic) $10
Interior door lock pulls $7
Seat hold downs 3 $10
Steering shaft u-bolt and clamp $5
Glove box front plate $15
Exterior
Convertible top windshield SS molding (3) $95each
Convertible interior windshield top SS (2)$75each
Convertible interior left side windshield SS $130
Fuel injection emblems offer
Side flags offer
Corvette script offer
Mirror (Bowtie) broken glass $10
66 Gas door assy $25
Front bumper cross bar good as core $35
Rear license plate bezel $9
Under hood/ front end
Hood hinge $5
Steering shaft Lower bearing & hardware $25
Fuel tank sender assy $25
Washer bottle and lid $7
Washer cap and hose $2
Hood support $ 20
Center Exhaust support $ 10
Front sway bar brackets and bushings $5set
Big parts
Front damper $120
Crank pulley $100
PS pulley $75
Gas line to carb 3 pcs. $25
Alt pulley $30
Alt bracket $30
Alt brace $10
Acc lever $10
Dist cover 3 pcs $100
Crank pulley 3850838 67-427 & 69 427 2nd des $50
Starter nose big block $20
Valve cover retainers big block $3 /set (7)
Carburetor body L88 38860091 3418-1 $75
MIS
13/16 sway bar $60
Tire tub $100
Rear exhaust panel (filled holes and center cut for exhaust) $50
Radiator shroud $100
Rear cross member solid mounts $45
66 radiator dated 65 M $100
16 x 10 5”x5”bolt pattern weld wheels 6 wheels $150
NOS parts
Horn lock tab $15
New Repo parts
battery cover $ 25
Frame end plates$3
Special parts
1963 Parts
824 Horn relay $40
Fuel pump 4657 $75
087 coil $50
Classic parts
generator tac gear
Engine
Accelerator Rod $7
Rear end parts
Interior Parts
Exterior
Side flags offer
Hood hinge $5
Hood support $ 20
Big parts
Front damper $120
Crank pulley $100
PS pulley $75
Alt pulley $30
Alt bracket $30
Alt brace $10
Acc lever $10
MIS
13/16 sway bar $60
Tire tub $100
PM Sent on the following
Fuel pump 4657 $75
087 coil $50
Fuel pump 4657 $75
087 coil $50
Hello, In the category of Interior: What year corvette is the hood release handle and cable? Is it original with the part number on the back side of the hood release handle? has the cable been snapped off at the end or is it the original length? I'm looking for a useable original 67 hood release handle and cable. Send pics to Teamsmith@comcast.net Thanks Chuck. If correct, I will purchase immediately!
Location: About 1100 miles from where I call home. Blue lives matter.
Received 5,323 Likes
Still interested in tire tub, no response to PM.
