63-67 Corvette – lots of great little stuff !! Look !!
63-67 Corvette Parts – most are new in sealed bags from LICC or Paragon – most prices are 40-50 % off original cost. Please Email me at mart78b@aol.com with what you want and I will let you know if it is still available. Prices are as marked plus shipping cost to your zip code.
63-82 Idler Arm replacement part used/ like new 30.00
63-67 Glove Box light socket/switch/bulb assembly new 10.00
65-67 Clutch cross shaft 396/427 w/ clutch stud to frame assbly new 50.00
63-67 Clutch ball stud to engine new 8.00
63-67 Coupe dome light lens new 3.00
63-67 Clutch fork bearing spring clip w/ rivets new 3.00
63-67 Bell Housing ball stud new 4.00
63-67 Front stabilizer link bolts/spacers/washers/nuts used/like new 3.00
64-67 Power Brake check valve/hose/clips/grommet new 12.00
63-67 floor 8-piece floor plug set SOLD
65-66 Power Antenna ground strap used/like new 2.00
63-73 Rear License plate attach kit SOLD
65-66 Power antenna mounting nut plate new 5.00
65L-67 3 hole Clutch Rod Boot retainer w/rivets new 4.00
63-66 Rear seat mount plates with rivets (pair) new 12.00
65-67 Dash switch plates (4 set Temp/Air/Vol/Tune) no A/C SOLD
65-66 Original Power Ant underbody spacer original 15.00
[Modified by 66BBCoupe, 1:33 AM 8/22/2002]
Re: 63-67 Corvette – lots of great little stuff !! Look !! (66BBCoupe)
Interested in your glove box switch/lamp assy and your temp/air/vol/tune switch plates. If they are still for sale I would like to buy them.
BayRay
BayRay
